Author Topic: EEVblog #262 - World's Simplest Soft Latching Power Switch Circuit  (Read 6161 times)
Offline HopWorks
I absolutely love your videos! Usually, analog+me=fire! but your detailed explanations of the theory has given me confidence, and I have less fires and explosions on my breadboards now. So not only have you helped my understanding of electricity, you have helped to save? the world as well! Hey! Bob's your uncle! Great job and thank you!
It would be nice if you had parts links along with your video's though. I tried searching for an IRF9110 as used in your circuit but came up empty. I found a lot of P-Channel Mosfets, but without a full understanding of Vgs (+-20v???), I can't figure out a replacement.
Anywho... NICE JOB!
Offline IanB
Re: EEVblog #262 - World's Simplest Soft Latching Power Switch Circuit
« Reply #1 on: December 11, 2012, 10:15:09 am »
 :o
Fires and explosions? Well, electronics for you is certainly more exciting than for most people!
Offline HopWorks
« Reply #2 on: December 11, 2012, 10:40:49 am »
 :o
You have no idea.  :scared:
Offline Fezder
  • Lean on, or was it learn on?
« Reply #3 on: March 28, 2013, 06:20:40 am »
Nice tutorial, easy looking schematics and well explained. BUT, i did of course try this out, 'been looking this kind solution/s for some time. mine version of that first one which has 2 push-buttons, doesn't latch.  it turns on right away, and turns off only the time i hold the off button. i've checked wirings many times, i'm confused what's the problem :D.  i dont know is it because of  incorrect components but here's the list if anyone could lend a hand:...
and sorry if this is NOT the place for asking help :S.
not even SCR equilavent circuit worked, tired that too, same symptoms.
ps: its not the end of the world, but i found couple other latching circuits which i succeeded to get working
supply voltage is 12v
transistors: bc547 / bc557
resistors: both 1k, tried 10k and 100k
load was LED with 1k resistor
Both analog/digital hobbyist, reparing stuff from time to time
Offline con-f-use
  • Country: at
« Reply #4 on: July 07, 2013, 09:15:29 pm »
I can confirm that the first schematic does in fact NOT work with a BC527/537 combination.
Here is what I used for a small ?C-project. It's not pretty but very simple and does the job. The 2N7000 is only rated for 200mA so others might need something beefier. Also it switches ground, which generally is a bad idea, but should be fine for 5V. I don't care about the cap slowly leaking and eventually turning the whole thing off by itself as it never runs more than a day anyway and the circuit gave me not problems.
Additionally because I'm tired of looking, for your convenience here the links to a few spin-offs:
http://www.eevblog.com/forum/beginners/world%27s-simplest-soft-latching-power-switch-circuit-%28modification%29/msg121811/#msg121811
http://www.eevblog.com/forum/projects/two-mosfet-soft-latching-startup-switch/msg167730/#msg167730
http://www.eevblog.com/forum/projects/characteristics-of-a-soft-latch-power-switch/msg152164/#msg152164
http://www.eevblog.com/forum/projects/yet-another-self-latching-mosfet-switch/msg171647/#msg171647
http://www.eevblog.com/forum/beginners/world%27s-simplest-soft-latching-power-switch-circuit-%28modification-2%29/msg121872/#msg121872
http://www.eevblog.com/forum/projects/an-improvement-on-the-soft-latching-power-switch/msg171112/#msg171112
http://www.eevblog.com/forum/projects/mosfet-power-switch-with-auto-off/15/
« Last Edit: July 07, 2013, 09:26:37 pm by con-f-use »
Offline opty
  • Country: ie
« Reply #5 on: December 20, 2013, 09:58:37 am »
In the first circuit PNP's leakage current will immediately pull NPN up.
You could add a resistor (parallel to the off switch)  to prevent it.
Offline jimjam
« Reply #6 on: June 15, 2014, 03:51:31 am »
I just discovered this while breadboarding it :) Why is there a leakage current?
« Reply #7 on: June 15, 2014, 03:55:40 am »
Because real transistors always have some leakage current, so there is leakage. Typically you will add a resistor between base and emitter of both transistors to ensure that they will stay turned off even with a low amount of leakage. In this particular circuit 100k or so will work, as the leakage currents are in the femtoamp region. If you are driving big power devices then you will be much lower in value.
Necromancing the thread..........
