Author Topic: EEVblog #633 – Mailbag  (Read 16485 times)
Offline wilfredTopic starter
« on: June 24, 2014, 02:56:08 am »
« Last Edit: July 28, 2018, 06:22:32 am by wilfred »
Offline miguelvp
Re: EEVblog #633 – Mailbag
« Reply #1 on: June 24, 2014, 03:27:05 am »
It's customary to embed the video, so here:
Offline Rory
« Reply #2 on: June 24, 2014, 04:07:43 am »
Dave, at 18:40, those "standoffs" are hinges.
Offline moemoe
« Reply #3 on: June 24, 2014, 06:28:47 am »
Looks like ShowView was only called ShowView in some contries "It is known as VCR Plus+ in the USA and Canada, G-Code in Japan, China, New Zealand and Australia, VideoPlus+ in Ireland and the UK and ShowView in the rest of Europe and also in South Africa" http://en.wikipedia.org/wiki/Video_recorder_scheduling_code.
This device is probably some sort of showview-remote for VCRs that don't support showview internally, and just sending the right ir remote commands for record/channel/stop recording at the correct time.
https://github.com/maugsburger/
Breadboard Adapters featured in EEVBlog #573 on Tindie
Offline nathanpc
  • Country: br
    • Innove Workshop
« Reply #4 on: June 24, 2014, 12:06:48 pm »
In my opinion the microscope stuff deserved a dedicated teardown. Also, was anyone able to find a schematic for any of those boards?
« Last Edit: June 24, 2014, 12:08:44 pm by nathanpc »
Offline edy
    • DevHackMod Channel
« Reply #5 on: June 24, 2014, 01:12:30 pm »
Dave, I didn't finish watching before I commented but the pulse counter "antenna" mounts looked like they were designed so you can swing the board up like the hood on your car, for servicing. You took the screws off the mounts but probably didn't have to. Nice video!
Offline Dave Turner
« Reply #6 on: June 24, 2014, 01:16:50 pm »
Rory - you beat me to it!  ;D
Offline craigh
« Reply #7 on: June 24, 2014, 04:01:37 pm »
I started my electronic career in the late 1970s repairing equipment built like your microscope module.  That right-angle standoff is actually a hinge so you could swing the board up to work on it without removing it (as someone has already commented).  Saw lots of those in my day.
Wire-wrapping was common then as well, and quite reliable.  The fine gauge (32AWG) wire wrapped around a square pin was deformed on the sharp edges and formed a gas-tight connection.  Lasted for many years.  The wire-wrap on your microscope module is likely still good today.
Equipment that had multiple boards plugged into a backplane often had the connections on the backplane made with wire-wrap (DEC mainframe computers for example).  I've made a number of prototype boards in the past using wire-wrap instead of soldered point-to-point connections.  You once could easily get DIP sockets with wire-wrap pins.  I still use the fine wire for making 'kludges' ('bodges' as you say Dave) on prototype boards or for making repairs.
I'm enjoying your videos - interesting and informative.  Keep 'em coming. :-+
Offline tecman
« Reply #8 on: June 24, 2014, 06:36:30 pm »
Dave:
You blew it.  those "stand offs" are actually hinges.  Remove the opposite screws and flip the board up !
Paul
Offline nixfu
« Reply #9 on: June 24, 2014, 09:10:55 pm »
Hey!    Where is the "Teardown Tuesday" video!?   :-//
I was excited to see that classic multimeter.  Isn't it already WED in Aussiland?   Slacker.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #10 on: June 24, 2014, 09:13:10 pm »
+1 to nathanpc's comment about a separate teardown for the microscope. Or perhaps a double-feature together with the metrawatt teardown.
Since its inception the TI-30 was a calculator (or an "electronic slide-rule calculator" as it showed in its box) designed to be the lowest cost possible. I have one manufactured in 1979 and its internals look very similar to yours (apart from the flex PCB, of course) - check example internal photos at the datamath's page.
Offline nixfu
« Reply #11 on: June 24, 2014, 09:24:28 pm »
Wow.   TI-30 with the red bubble display brings me back.  My dad (a mechanical engineer) had one of those on the desk in his office I would sneak in and play with and do square roots etc.  :)
Offline Smokey
  • Not An Expert
« Reply #12 on: June 24, 2014, 11:29:32 pm »
Watching someone eat their first Reese's Peanut Butter Cup as an adult and "live" on video was a little weird.  That's a staple of USA candy foods.  You don't go through a Halloween season without eating like 400 of those around here.
**Side note.... Stick them in the freezer.. They are pretty good (better?) cold.... Also blend them in icecream....
Offline nsayer
    • Geppetto Elecronics
« Reply #13 on: June 25, 2014, 03:03:20 pm »
Dave sort of missed the punchline of my letter (the last one). I wanted to give away a Hydra logic board to a lucky winner. If you freeze-frame the letter, you can read that in the last paragraph.  :-\
I'd still like him to pick the winner, but perhaps I'm asking for too much of his time.
Buy my stuff!! It's not at all terrible!! http://tindie.geppettoelectronics.com/
Offline Stonent
« Reply #14 on: June 26, 2014, 02:45:33 am »
I thought that too.
Offline Stonent
« Reply #15 on: June 26, 2014, 02:53:43 am »
Classic Commercial:
And of course around Easter, the Reese's Eggs come out. MMMMM...
Offline hikariuk
« Reply #16 on: June 26, 2014, 06:09:50 am »
I think I want to try one now.  The only American chocolate I've tried are Hershey's Kisses that an American ex-girlfriend gave me.  I concluded Americans didn't like nice chocolate.
I write software.  I'd far rather be doing something else.
Offline Towger
  • Country: ie
« Reply #17 on: June 26, 2014, 06:36:30 am »
Don't worry, you are not missing anything, your conclusions are correct.
Americans don't know what chocolate tastes like, they programmed at a young age to believe the main ingredients of chocolate is sugar:
Offline miguelvp
« Reply #18 on: June 26, 2014, 06:43:05 am »
Funny that chocolate comes from the American continent :)
But we all know the Swiss make the best chocolate. Herseys just make MOOOtritious chocolate (took my daughter to the factory tour some years back).
One thing I don't get is the European concept of Americans (as in the US) not knowing any better on anything when most of the stuff originates from here to begin with and the US is pretty much a conglomeration of the whole planet anyways.
Offline abaxas
« Reply #19 on: June 26, 2014, 11:42:26 am »
Bad teeth seams to be the largest current US export.
Offline LIV2
« Reply #20 on: June 26, 2014, 12:30:01 pm »
Yep! I had the exact same unit but branded as G-Code back in the 90's and it was pretty much a universal remote with a timer :)
It was pretty useful for recording some but not all of the program you wanted to watch
Offline Smokey
  • Not An Expert
« Reply #21 on: June 26, 2014, 10:33:35 pm »
Come on now... Everyone knows the brits have that market cornered!
Offline AlfBaz
« Reply #22 on: June 26, 2014, 10:52:20 pm »
LOL @ myself
Close up on the analog meter's needle and I instinctively closed one eye and moved my head side to side :palm:
Offline Dave Turner
« Reply #23 on: June 27, 2014, 04:41:38 pm »
Mike Myers is Canadian  ;D
Offline miguelvp
« Reply #24 on: June 27, 2014, 05:30:45 pm »
And those are not his real teeth,
Canadians like us in the US have dental insurance and affordable dentists :)
« Last Edit: June 27, 2014, 05:33:27 pm by miguelvp »
