Author Topic: eevBLAB #9 - Meet David  (Read 21025 times)
Offline nctnico
Re: eevBLAB #9 - Meet David
« Reply #25 on: April 23, 2015, 02:58:53 pm »
Now we are done with talking about haircuts (David: when do we get to see the new haircut?)
Windows runs just fine on a Virtual box in Linux. I'm using it all the time and I usually have 2 or 3 running at the same time for different projects/purposes. The best thing is that I can copy the virtual machines over to a new Linux PC without re-installing!
Offline cipher
  • Ohm's law hates superconductors
« Reply #26 on: May 08, 2015, 01:37:00 pm »
Having it run "just fine" does not mean perfectly. It's still not a true Windows environment from hardware to software. And when you're a developer like me that makes a huge difference. Network stability issues, driver framework issues, etc, etc.
Offline nctnico
« Reply #27 on: May 08, 2015, 10:52:56 pm »
Don't twist my words! If you are pushing the limits you'll alway find a problem somewhere. I have tested running Windows from a virtual machine thouroughly over a period of 2 years before switching. Even timing sensitive things like programming microcontrollers (toggling pins on a USB device) works flawlessly. The biggest problem I found is disk flushing which stalls the VM for a while (depending on cache settings) but I solved that by using an SSD.
Offline atferrari
  • Country: ar
« Reply #28 on: May 09, 2015, 04:37:49 pm »
... and who doesn't love the haircut?
I would describe it as: not having a haircut.
Strictly speaking, yes!  :-+
Agustín Tomás
In theory, there is no difference between theory and practice. In practice, however, there is.
Offline abigbell
« Reply #29 on: May 10, 2015, 10:00:33 am »
hello Dave, I do love your videos, and I have beening sitting in my chair for a whole long day, just listening to your bubblings and teardowns ,
and learn about lots of things, and thanks to you, tahnks to your sexy appearance and voice , my head is now dizzling  |O |O |O
can we have some soft sexy face and voice?  I love Cate Blanchett!
and I  dont belive your audience are more than 50%, what the hell wowan want to know about any electronics? :wtf:
