As others already mentioned, you did not show the power integral area correctly, i.e. from 0.8 to the discharge line only, instead of zero volt to the discharge line.
That is really annoying, and may disturb students, for whom this video is intended for, obviously.
The numbers come out exactly the same.
I assume you mean something other than that the apparent capacity remaining that one would get from integrating from 0.8V to the discharge line only would not differ from that if you instead integrated from 0 volts to the discharge line. In other words, the difference between measuring the "area under the curve" with the area's base at 0.8 V instead of the area's base at 0 V. Because, there is actually a substantial difference.
In a.png, I've sketched a hypothetical discharge curve at constant current. (I know that no cell actually behaves as depicted, but my purpose is only to illustrate the point.) Note that this curve drops vertically after it reaches 0.8 V, so in this case there is
no energy at all after this point.
In b.png, I've changed the vertical scale to only go from 0.8 V to 1.6V, and I've asked myself the question, "The cell has been discharged to 1.2 V, what fraction of the original energy remains?". Naively, I measure "areas under the curve" of this plot, and obtain the answer 25%.
In c.png, I keep the scale that starts from 0 V, and ask exactly the same question, now, when I correctly find the areas under the curve, find an answer which is more like 42%. So, where we measure our areas from does make a difference.
I believe that 42% is the correct answer and that this would agree with the spreadsheet method that you spent most of the time in the video explaining. The point though is that during the video, you did sketch over a discharge plot an "area under the curve" with a base at 0.8 V. If we forget about the need to add the rectangles down to the base at 0 V, we are liable to be mislead, often substantially. Even if we remember that the extra areas need to be added in, speaking for myself at least, it is very difficult to imagine the right amounts, and how this should change the interpretation. All this is just another example of the importance of using the right scale on a graph for a given purpose.
We can always, of course, compute and get the right answer, but the importance of the graphical method (in this case sketching the area remaining under the curve) is that done correctly, it gives us an intuition for what computed result we should expect --- that's good engineering.
So, my point is that using the graphs with the given scales is likely to substantially mislead our intuition about this problem --- and it happens to do so in the direction of suggesting less unused capacity than is in fact the case.
I've been getting the feeling that in this group, saying that there is more energy left than looking at the (wrong) area suggests, makes me look like I am trying to support Batterizers (sp?) claims --- I'm not. The numerical calculations that Dave made (with the spreadsheet), are (I think) correct, and the unbiased visual depiction of the areas under the discharge curve would support them.
