Author Topic: EEVblog #801 - How To Design A Digital Clock  (Read 89953 times)
Offline LabSpokane
Re: EEVblog #801 - How To Design A Digital Clock
« Reply #50 on: September 24, 2015, 08:37:58 pm »
Really cool clock Dave!
Clever using the mains frequency as clock, love the discrete diode/transistor logic and the 0.1 second display was a nice touch!
I read once that utility companies used to adjust the number of cycles during the day for the benefit of clocks like this.
Anybody knows if this is true?
True.  Using the mains frequency as a clock synchronizer is how clocks kept time for decades.  And the number of cycles was adjusted mainly as an efficiency and power plant capacity issue.  The frequency would slow down during the day as the load increased, then it would be correspondingly sped up at night so that each day would have the same number of mains frequency cycles.
BPA, I believe, did a test recently to see how many systems were still dependent on mains synchronization for timing.  The answer was: not many.  They may actually allow the mains frequency counts to vary from day to day in the future.  You would need to check with the operators of your particular power grid to know how they are handling this now.
Offline LabSpokane
« Reply #51 on: September 24, 2015, 08:41:02 pm »
And could I request that everyone just shut up about the whole Ahmed situation now?  That is just going nowhere.
This thread is about building a clock.  And that's something really damned cool - and a very accessible, basic-building block project for a lot of interested electronics folks.
« Reply #52 on: September 24, 2015, 08:42:01 pm »
Used to be true, but now most have decided that they will allow a certain number of cycles slippage with heavy load and will not recover them at night with low load. You might be lucky in that you only lose a few seconds per month, but they pretty much decided it was too expensive to get the controllers to aim for midnight on the master clock to agree with UTC.
Offline Macbeth
« Reply #53 on: September 24, 2015, 09:17:59 pm »
All well and good, Dave.  Righteous clock design.  However, I must call bullshit on the Ahmed bandwagon.  Here are the updated facts and context:
2.  The clock was altered into a countdown timer, rather than an RTC.
3.  Said clock/timer was executing an active countdown when the incident occurred.
4.  The entirety of the situation resembled nothing more than an improvised explosive detonator being taken into a public school.
Good Job, all factual.
I love it when someone posts the truth in such a concise form.  :-+ :-+
Me too. This is great. Of course I am assuming you septics just using the kind of sardonic humour us limeys are known for?  ;)
I mean as that great American John McEnroe stated "You cannot be serious!?"
As for Achmed, I think all of us and the media should just forget about it, at least until we find teachers being sacked for political correctness reasons or some other outrage. Dave closed the last thread, so I don't know why he effectively started another.
Offline Dinsdale
    • pretzelogic
« Reply #54 on: September 24, 2015, 09:19:23 pm »
Yeah, that clock is the bomb, Dave.
This can't be happening.
Offline Macbeth
« Reply #55 on: September 24, 2015, 09:20:33 pm »
Kitchen clocks all used to run on the mains to keep time in the UK, but then cheap batteries and 32.768kHz crystals took over. Later we had accurate clocks using radio broadcasts for synchronisation. Now it's NTP.
Offline Howardlong
« Reply #56 on: September 24, 2015, 09:30:14 pm »
+1. Thank you.
Offline alien_douglas
« Reply #57 on: September 24, 2015, 10:47:20 pm »
Great clock Dave.
I never ever made a clock. I did make frequency counter that did look very similar in construction to your clock.
I love veroboard  :)
Great stashes of old components, brings back memories.
My first ever job was as an electronics service engineer for IBM. I also collected many 7400 series chips from old faulty boards. The big problem was that IBM used to part number almost everything back in the eighties.
Although it may have been a standard TI 7401 TTL chip it would only have an IBM part number on it.  I could never remember all the IBM seven digit part numbers so a translation list was a must.
And yes, everything was part numbered especially for IBM, from SnapOn tools to Tektronics scopes.
And my favourite CMOS chip that I used everywhere was the 4017 (Not the 4026. Sorry Dave.)
I used to make blinky LED lights for my scale model projects. 4017 rocks...
Alien
Online tggzzz
« Reply #58 on: September 24, 2015, 10:51:52 pm »
Not quite. For many decades non-clockwork clocks used the mains frequency as the time reference. LED digital clocks were a latecomer.
I believe that the average frequency is still required to be 50Hz. IIRC there are some moves to remove that restriction - not least because we are down to about a 2% capacity margin. Why? Due to the total failure of the market (with the complicity of government) to provide adequate generating capacity.
Online tggzzz
« Reply #59 on: September 24, 2015, 11:00:57 pm »
Here's my variant, from around 1973: https://entertaininghacks.wordpress.com/2015/02/21/a-40-year-old-hack-disinterred/ and construction techniques: https://entertaininghacks.wordpress.com/2015/02/21/vintage-hacking-or-the-past-is-a-foreign-country-they-do-things-differently-there/
Blah, it uses one of those new-fangled integrated clock chips, sacrilege!
Well, at that time TTL was very new, very expensive[1] and required an "accurate" 5V supply - all of which was a problem for an impecunious youngster.
[1] especially 7447s, looking at the adverts in http://www.americanradiohistory.com/Archive-Wireless-World/70s/Wireless-World-1973-02.pdf
Offline g0hjq
Re: EEVblog #801
« Reply #60 on: September 24, 2015, 11:15:28 pm »
My first major project was a TTL digital clock, built during the school summer holidays in 1977. It used a 4:12 decoder and a diode matrix for the 12 hours display.
More recently, I've just finished building a kit using discrete Diodes/Tranistor logic with around 200 transistors, 500 diodes and no ICs. http://www.transistorclock.com
« Last Edit: September 24, 2015, 11:19:33 pm by g0hjq »
Offline Howardlong
Re: EEVblog #801
« Reply #61 on: September 24, 2015, 11:27:55 pm »
Beautiful. Pornographic even.
Offline Macbeth
« Reply #62 on: September 24, 2015, 11:31:06 pm »
Oh wow, I love going through old magazines... Page a16 "Candles are for eskimos" totally takes me back to the 70's, I can't remember a time when the 'leccy wasn't cut. The UK was worse than North Korea at the time. Though I think it wasn't just the national strikes but my parents being out of work and out of 50p's shillings for the meter just as often. I totally remember the candles. It's also why I loved my crystal set. Those Ever-Ready batteries never lasted more than 5 minutes  ;D
ETA: The 50p's were for the, can you believe it, pay-slot colour TV. I preferred the black and white because we could have that on any time. To use the colour we had to put 50p in the slot and wind a dial and then it would tick away...  :-DD Oh fuck, life was grim in the '70s...
« Last Edit: September 24, 2015, 11:39:33 pm by Macbeth »
Offline EEVblogTopic starter
« Reply #63 on: September 24, 2015, 11:37:51 pm »
1.  Ahmed did not design that "clock" from scratch.  It was an existing Radio Shack clock removed from its enclosure and remounted into a briefcase.
For the 1 millionth time, everyone knows this. It was bleedingly obvious to anyone with electronics knowledge who saw that photo.
So what? Beginners have to start somewhere, many of us were in the exact same position.
I call bullshit. Provide proof.
Exactly how do you modify a commercial clock chip to down?
Please be precise and technical in your answer.
Because if experiences electronics people don't know how to do it, I'm pretty sure Ahmed, who is clearly a rank beginner has no clue how to do that.
« Reply #64 on: September 24, 2015, 11:40:00 pm »
5.  Ahmed Mohamed's father, instead of consulting with the school board (which is the legal and responsive authority on this matter), has contacted CAIR, which is in the process of manufacturing a racial incident out of this event.
6.  The same father, a known jihadist, has twice ran campaigns for the presidency of Sudan, which last I checked, is not known as a wellspring of democracy but is known for impressing children into suicide bombers, as part of President Bashir's policy of global jihad and arms supply to Hamas and Hizbullah.
Crap job, reposting bullshit (consisting of lies mixed with some real information) found in sewers of internet.
We all are entitled to our opinion.
One thing you and I have in common, we were not there to witness any of the facts.
There is no need for opinion, this is purely a technical question. Please explain how a commercial desk clock chip can be modified into a countdown timer.
« Reply #65 on: September 24, 2015, 11:43:55 pm »
Dave, did you not use PNPs at the time?
Sure, but NPN's worked just fine.
Offline LabSpokane
« Reply #66 on: September 24, 2015, 11:44:46 pm »
Picture help:
http://www.ebay.com/itm/Micronta-Vintage-Digital-Alarm-Clock-with-Large-Red-Display-63-765A-/271992316574?hash=item3f5401629e
Buy this clock for over $150 and prove Dave and common sense wrong.
« Last Edit: September 24, 2015, 11:46:59 pm by LabSpokane »
« Reply #67 on: September 24, 2015, 11:47:25 pm »
We do tend to use what we cut our teeth on.
:) Dave made a comment regarding microcontrollers in the video. We actually had the 8031 and the 8051 before 1980.
Yes, but almost no one in the hobby field used micro's until basically the PIC16C84 came out in 1993 (no flash parts then).
It was not a cheap or easy field to get into like it is now.
« Reply #68 on: September 24, 2015, 11:48:05 pm »
How do you adjust that clock?
If it's all BCD overflow logic, does that mean you have to run to every 10th of a second to get to the right time?
By very careful fast forwarding.
Offline Macbeth
« Reply #69 on: September 24, 2015, 11:49:08 pm »
Especially by a lad who clearly doesn't know one end of a soldering iron from the other. I mean it doesn't work both ways. He's either a rank amateur who knows how to twiddle a screwdriver, or a genius bomb-maker who goes to the extreme of reverse engineering a fucking radio alarm clock instead of going with a much simpler 555 timer or Arduino or the good old mechanical switch on the minute hand trick... In fact I remember using potassium permangate and glycerine as a fuse - no electronics or mechanics needed.
« Reply #70 on: September 24, 2015, 11:50:36 pm »
As always, I'm happy to be proven wrong.
It might very well have a countdown timer in it, but can't say I've ever seen one.
And if it does require some form of technical hack to do it (no evidence of in photo), then Ahmed has much better skills then it seems half the world is shooting him down in flames for lack of.
« Last Edit: September 25, 2015, 12:06:40 am by EEVblog »
Re: EEVblog #801
« Reply #71 on: September 25, 2015, 12:07:53 am »
Wow, very nice!  :-+
Offline Deathwish
  • Country: wales
« Reply #72 on: September 25, 2015, 12:11:12 am »
You must of lived next door to me !. ditto
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
Online tggzzz
« Reply #73 on: September 25, 2015, 12:36:09 am »
I still keep candles, and have very occasionally used them.
I'll stock up next year, before the lights go out again - this time because we don't have the generating capacity. See https://www.ofgem.gov.uk/publications-and-updates/security-electricity-supply-faqs and read between the lines :( Or maybe the domestic lights won't go out, because the businesses on cheap rates will get "load shedded".
Some things were better (e.g chemistry lessons), some weren't (e.g. bicycle lights).
Offline kwass
« Reply #74 on: September 25, 2015, 12:51:55 am »
Maybe not that cheap but it was easy ... mostly becasue of Digikey (not sure if they sold outside of the US back then).
There was the INS8073 chip and development board.  The INS8073 had NSC Tiny Basic built in and the development board that Digikey sold (can't remember the model number of this)  provided the hardware for writing tokenized BASIC programs directly to EPROM.
http://www.classiccmp.org/cini/pdf/NatSemi/INS8073_DataSheet.pdf
You didn't need anything more than a dumb terminal and simple power supply to start using this micro for projects.  It was on the expensive side but I made a few projects with them.  This was was back in 1981, way before the PIC and the BASIC Stamp, etc..  There were a few other single chip/development boards too that were targeted for hobbyists.
Back then and well before that, Digikey was only a hobbyist company.  They started off selling surplus electronics via a typewritten and hand drawn 8 page catalog.  Later they sold a lot of NSC clock modules and PCB kits to "make your own".  I used to make those to order for my family and friends, there were lots of options to pick from on these modules: alarms, temperature display, date display, etc..  Digikey had interesting stuff before they started selling to the industry.
« Last Edit: September 25, 2015, 12:55:04 am by kwass »
-katie
