Author Topic: EEVblog #807 - Mailbag  (Read 28095 times)
Online EEVblogTopic starter
« on: October 12, 2015, 12:46:39 pm »
More Mailbag
Items from Lithuania & Israel!
SPOILERS:
JigMod Kickstarter: http://kck.st/1LwT4iA
A Breadboarding prototyping system
Lumintop Tool AAA Keychain LED Torch/Flashlight
http://amzn.to/1jr4Nbs
1992 Sony Video-8 Camcorder
Fluke 196 100MHz 1GS/s Scopemeter
And a security networking chip teardown
Offline Fungus
Re: EEVblog #807 - Mailbag
« Reply #1 on: October 12, 2015, 01:33:07 pm »
What happened to the Fenix LD01?
Don't like the look of that key ring attachment. My bet: The rubber switch will be broken in less than a month.
Maybe you could attach the key ring using a zip tie or something.
Offline Barny
  • Country: at
  • I'm from Austria, not Australia ;)
« Reply #2 on: October 12, 2015, 02:08:08 pm »
A little hint:
Old cameras, tablets,.... don't like big SD-cards.
They work only with SD cards up to 2GB.
Offline German_EE
« Reply #3 on: October 12, 2015, 03:18:17 pm »
OK, I'm missing something, what is so special about Shermer IL?
Warren Buffett
Offline Cliff Matthews
    • General Repair and Support
« Reply #4 on: October 12, 2015, 05:03:17 pm »
Yup, Ontario was pronounced bang-on! (pop. 14 million, only California, Texas, NY and Florida are bigger). That kick-starter looked novel, he's from my area (what they call Canada's Tech-Triangle). I think I'll have to pay him a visit.. Thanks Dave, you must visit! Ontario's almost as awesome as EEVblog!
Offline AF6LJ
« Reply #5 on: October 12, 2015, 05:09:52 pm »
Good Stuff Thanks Dave. :)
Sue AF6LJ
« Reply #6 on: October 12, 2015, 05:25:54 pm »
No idea ( don't watch TV), so not a clue.
As to the rings on the BGA package, they are there as part of the package design, to provide a fixed edge when routing out the layers so they do not peel or delaminate, and then a nice alignment aid for the bonder vision to recognise the ends of the multiple layers when bonding.. The copper planes will be power and ground planes, there as the chip needs high current and having this power and ground plane next to each other with only a thin laminate means the low capacitance is very effective and is very low inductance. Might be only 100pF for the whole set of planes, but the inductance is essentially mostly there from the multiple bond wires feeding the chip. For security there would be another laminate over the whole lot, with a similar one as the lowest laminate layer ( or just one in from a routing layer), with a few traces meandering across and connected to ground and the power rail, and also feeding the standby voltage that keeps the on chip RAM used for program storage alive. One or two microvias will link them at random across the BGA ball area to internal layers, and then to the chip. The power wires will be designed so they will short out to each other when you try to probe, and the traces connect to the die to enable it. Some self destruct (  a lot of high power IO cells connected together in the chip periphery  that are normally tristated, and if tampering is detected they are turned on with the high and low side drives turned on so shorting the chip to cook it quickly). Same with the lid, though there you will need to have a connection made with silver loaded epoxy to the top mesh.
This chip does not have that, it is a regular ARM processor in a BGA package. No security, as the program resides in the external EEPROM, where it is trivial to read. It just is hot running, so they put the big passive cooler onto the package with a really good adhesive. Then there is 64M of DRAM right next to that for the Linux OS to run in.
Offline pascal_sweden
  • Country: no
« Reply #7 on: October 12, 2015, 06:37:34 pm »
Dave,
You need to use a small ring, and connect that small ring to your key ring.
Don't use the key ring directly.
The Maglite flashlights come with such a small ring if you look for an example :)
Offline crispy_tofu
« Reply #8 on: October 12, 2015, 07:49:16 pm »
Good to see the JIGMOD has reached its goal!  ;D
Offline free_electron
    • SiliconValleyGarage
« Reply #9 on: October 12, 2015, 08:21:15 pm »
the rings int he BGA are the power rings. they bond from the DIE directly to the rings. nothing special.
as for the scopemeter : you will find on the bottom of the board, dead center a toeasted sot23-6 power mosfet.
that fet is obsolete. it can be replaced by a n FDC666 provided you cut off one of the pins. the mosfet uses a non standard pinout.
Offline Rasz
    • My random blog.
« Reply #10 on: October 12, 2015, 08:36:37 pm »
is there really a pcb material between the die and package metal plate in this BGA chip? that sounds terrible from thermal point of view
Offline AF6LJ
« Reply #11 on: October 12, 2015, 08:40:50 pm »
Those chips are usually mounted upside down on the PCB that is the chip carrier, the backside of the chip faces the heatsink AMD use to build processors that way.
Sue AF6LJ
Offline Rasz
    • My random blog.
« Reply #12 on: October 12, 2015, 09:41:11 pm »
flip chip etc, yes I know
but in this particular one it looked like the chip Dave ripped open was like the third in the upper row kind:
and it looked like the die stayed  with most of the chip, then there was a cover of some laminate material ... then we get same llaminate material glued to the rest of the chip still attached to heatsink. So it appears metal window in chip package is completely useless
look at 34:60 in the video, you can clearly see pcb material between the die and metal plate, there even appear to be some thermal compound on the inside, WTF
Offline Xenix
« Reply #13 on: October 12, 2015, 11:45:43 pm »
Shahriar from The Signal Path has made a taredown and repair video on the Fluke 196b...
Maybe it will help with the repair :)
« Last Edit: October 12, 2015, 11:49:38 pm by Xenix »
Offline Stonent
« Reply #14 on: October 13, 2015, 01:52:00 am »
And just for whatever reason, there's Ontario, CA (Canada) and Ontario, CA (California, USA)
Offline Stonent
« Reply #15 on: October 13, 2015, 01:58:18 am »
I recognized the package as being similar to what Intel used in the early 2000s for their chipsets like the i810 and VIA used for the VT8286A.
Here's a different view of a similarly packaged chip:
Offline max666
  • Country: at
« Reply #16 on: October 13, 2015, 02:17:53 am »
No, I think you see it wrong. The die must be right against the metal window, under the white stuff. We don't see the die at all, we see only laminated material of the interposer. Dave separated the laminated fibre gals of the interposer, so we see laminated layers still stuck to the heatsink and a hole in laminated material of the interposer still on the board. I guess the white part in the centre is some material to grout the bond wires, but I have no idea how they bond those chips, I know nothing about that.
Offline AF6LJ
« Reply #17 on: October 13, 2015, 03:20:49 am »
Director John Hughes set many of his movies in the fictitious suburb of Shermer.
http://thelister.blogspot.com.au/2010/06/ten-movies-featuring-fictional-town-of.html
I must be culturally deprived I don't even know who John Hughes is.
Sue AF6LJ
Offline leroy_is_brown
« Reply #18 on: October 13, 2015, 03:31:22 am »
You might have seen his films though - "The Breakfast Club", "Sixteen Candles", "Ferris Bueller's Day Off", and "Home Alone" ring any bells?
If you aren't in over your head, how do you know how tall you are?
Offline AF6LJ
« Reply #19 on: October 13, 2015, 03:34:45 am »
They all do but the only one I thought was any good was The Breakfast Club
Sue AF6LJ
« Reply #20 on: October 13, 2015, 03:39:38 am »
Definitely my favourite as well.
Offline jonwil
« Reply #21 on: October 13, 2015, 05:30:39 am »
John Hughes is a guy who owns a lot of car yards in Perth http://www.johnhughes.com.au/ :)
Offline adcurtin
« Reply #22 on: October 13, 2015, 06:46:08 am »
SD cards that are 4GB are rare. Most 4GB cards are SDHC, which is a newer spec. SDHC is from around 2006 (I have a monitor from 2007 that still doesn't do sdhc). That camera said 2002 when powered on, so it is most likely too old to work with SDHC. A 2GB or less SD card should work fine.
Offline Fungus
« Reply #23 on: October 13, 2015, 06:56:30 am »
Maybe it doesn't generate much heat.
Offline Vgkid
« Reply #24 on: October 13, 2015, 05:01:25 pm »
That chip breaking like that, sure was interesting.
Offline Ampere
« Reply #25 on: October 13, 2015, 08:24:35 pm »
The JigMod looks really interesting. I'll have to keep an eye on that.
I would definitely like to see a troubleshoot (or at least a teardown) of the scopemeter. I've never even used a scopemeter let alone seen inside of it.
Offline Balaur
« Reply #26 on: October 13, 2015, 09:06:53 pm »
About JigMod ...
Please have a look at the funding trends:
https://www.kicktraq.com/projects/electroniclaunchpad/jigmod-electronic-circuit-building-system/
Nice ramp-up in the last couple of days. After the presentation in the Mailbag episode. Hmm...
« Reply #27 on: October 13, 2015, 11:55:58 pm »
You guys love to copy.. There's Toronto Ontario (you know the 5th largest city on the continent) and then for whatever, there's seven Toronto's south of the border.. What's next? Jigmod will go all American. Sorry, it's not a rant - it's just Canadians like to say sorry (especially during elections..)  ;)
Offline AF6LJ
« Reply #28 on: October 14, 2015, 12:54:59 am »
I wonder if he is like Cal Worthington.
Sue AF6LJ
Offline Len
[OT]
« Reply #29 on: October 14, 2015, 03:11:01 am »
Wow, that's a blast from the past!
DIY Eurorack Synth: https://lenp.net/synth/
Offline AF6LJ
Re: [OT]
« Reply #30 on: October 14, 2015, 03:30:07 am »
I use to enjoy his commercials on the Los Angles stations out here.
Sue AF6LJ
Offline Stonent
« Reply #31 on: October 14, 2015, 05:16:04 am »
Well there's only like 3 cities anyway in Canada, right? Toronto, Vancouver, and Montreal. :)
Wait, 4 ... I forgot Possum Lodge.  :-DD :-+
Offline crispy_tofu
« Reply #32 on: October 14, 2015, 06:44:31 am »
And Dog River, Saskatchewan  :)
And Sydney, the one in Nova Scotia that is  ;)
« Reply #33 on: October 14, 2015, 11:43:17 am »
..and 90% of us live under a 1-hour drive away from the USA, just to keep warm.. (we forgot how to build igloo's)  :-\
Offline AF6LJ
« Reply #34 on: October 14, 2015, 03:04:45 pm »
That's Cute.
I've been to Vancouver, nice place but wow the Sales Tax is a real killer.
Sue AF6LJ
Offline vlad777
« Reply #35 on: October 14, 2015, 06:04:34 pm »
That 3.3 M pixel camera needs ordinary 2GB card or less .
None of these sd HC rubbish.
(HC stands for high capacity, I think.)
« Last Edit: October 14, 2015, 06:06:13 pm by vlad777 »
Mind over matter. Pain over mind. Boss over pain.
Offline vlad777
« Reply #36 on: October 14, 2015, 06:08:24 pm »
If the head on that sony camcorder doesn't spin, but makes noises, than you have dead caps in the supply.
Offline cs.dk
« Reply #37 on: October 15, 2015, 03:54:17 am »
Where did you get the Brymen BM235 from? Brymen nor Google seems to know that model - Nice feature with the continuity triggered backlight, would have a great use in noisy invironments.
Is the BM235 the rebadge meter planned?
Offline Scottjd
    • YouTube Gadget Reveiws
« Reply #38 on: October 15, 2015, 04:52:36 am »
As a semi retired security professional (health issues) that used to work on those check point firewalls all the time it almost killed me to watch you tear off the chip like that. They were good security appliances back when, at one time they were Ciscos only serous competition. Stable as hell when they were set up good, would run for years without a reboot based on BSD as the main operating system.
Not sure even if you did troubleshoot it, you might not have been able to check or confirm it was fixed in the software side.The ones I managed were much bigger, enterprise level beasts.
Then I remembered the one long day (26 hours long) that we couldn't figure out the issue. Not even check point could help and it was their update that broke everything. Reversing the change didn't help either.
I wanted to rip the firewall out of the rack and do a tear down on it "Office Space" style.
CAUTION, THE FOLLOWING VIDEO MAY HAVE LANGUAGE NOT SUITABLE  FOR CHILDREN, AND MAY OFFEND OTHERS ALSO.
Please be sure to check out my YouTube channel and subscribe if you like the videos. https://www.youtube.com/c/GadgetReviewVideos
By people subscribing and giving thumbs up I know what I am doing is still wanted and adding value, then will continue to release new videos. Thank you for your support.
Offline boffin
« Reply #39 on: October 15, 2015, 05:08:33 am »
Health Insurance, $72/month (everyone qualifies).
<end of argument>
Offline AF6LJ
« Reply #40 on: October 15, 2015, 03:13:40 pm »
<end of argument>
I pay less here $52.00/mo.
But still that is a good deal Y'all have up there.
Sue AF6LJ
« Reply #41 on: October 15, 2015, 07:56:39 pm »
<end of argument>
Huh? We pay nothing in Ontario.  ..and we have the Blue Jays headed to the world series too  :-+
(I've never known why they call it world series when it's just two neighbors playing ball)
Offline Rasz
    • My random blog.
« Reply #42 on: October 15, 2015, 09:38:23 pm »
<end of argument>
I think you misunderstood. That $72 is for everything, there are no deductibles, no out of pocket bullshit. Things like emergency appendectomy will not put you in debt.
Offline AF6LJ
« Reply #43 on: October 16, 2015, 12:50:04 am »
<end of argument>
I did misunderstand; and I would like to see the list of what is deemed Medically necessary.
Sue AF6LJ
Offline cs.dk
« Reply #44 on: October 17, 2015, 10:24:14 am »
Is it only me that wonders about the BM235?
Offline Greenlight
  • Country: cn
« Reply #45 on: October 28, 2015, 08:26:27 am »
Where is LD01 ?
Offline Greenlight
  • Country: cn
« Reply #46 on: November 02, 2015, 01:12:35 am »
Where is LD01 ?
Just curious, I didn't see LD01 but only Lumintop Tool AAA and Thrunite Ti in the video. And with string for the flashlight hole to attached the  keyring will be nice as I have similar AAA light like that.
Offline Fungus
« Reply #47 on: November 02, 2015, 05:21:19 am »
Yes!
