Author Topic: EEVblog #84  (Read 17034 times)
Offline RayJones
    • Personal Website
Re: EEVblog #84
« Reply #25 on: May 06, 2010, 07:22:44 pm »
The modulator in our radar near Dave's workplace can deliver 2400A, 600V, 2us pulses @ 500Hz.
I figure that works out to 1440Joules (simply multiply the lot together?)
After the step up transformer, there is close to 60kV applied to the klystron tube (at a reduced current of course)
I reckon that 60kV pulse could really blow some things apart!
alm
  • Guest
Re: EEVblog #84
« Reply #26 on: May 07, 2010, 01:57:26 am »
yes true the probes are rated for 600 V but I'm only measuring transients or back EMF, if the probe was damaged I would not be so bothered, it is the scope i want to stay intact.
Lets hope that the probe fails open circuit, not short circuit ;).
so does CATI 300 V mean that it will withstand a continuous voltage of 300 V even though the max input is 40 V ?
I don't think the equipment ever has to work for IEC 1010, IEC 1010 is purely about not injuring the user. So the CAT ratings are about not exploding or catching fire. There should be a separate max non-destructive input voltage rating spec in the manual, this is the limit that it should actually survive without damage. This limit is likely to be higher than the max. vertical range, but may not be 300V.
Offline Kiriakos-GR
  • Banned!
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
Re: EEVblog #84
« Reply #27 on: May 07, 2010, 03:19:01 am »
For me, the greatest transient that came close enough to damage my isolation,
as thinking unit, was this look ..    ;D ;D ;D ;D
Its a mixture of Star Trek look, with Australian glamor  :D
I like teasing people ... I do not know if it works in this case  ;)
« Last Edit: May 07, 2010, 03:22:16 am by Kiriakos-GR »
Online Neilm
Re: EEVblog #84
« Reply #28 on: May 08, 2010, 03:59:02 am »
The CAT rating system is more or less as following:
CAT IV. The wiring from the power station, the voltage distribution, transformers etc up to the input of the electricity meter.
CAT III. The wiring from the meter to distribution board, large switch gear and high power outlets.
CAT II. Internal wiring up to the mains plug in the wall.
CAT I. Every thing powered through a transformer from a CAT II source.
Multi-meters should be tested to IEC61010. This calls for transient tests on the inputs of a mains voltage from a low impedance source with a transient super imposed on it. For instance a 600V CAT III meter should be tested with an 6kV transient superimposed on 600V capable of delivering at least 3000 Amps.
The IEC61010 Ed 2 is a bit vague on should the instrument still work. Most from reputable companies will work. (I would guess the resistor that was damaged on the Fluke lead to problems when the transient happened). I believe that the soon to be published Ed 3 will require the instrument to be undamaged.
I have read comments along the lines of "I've had things explode in my hand and have never had a problem". A couple of years ago I tested a 2 pole voltage probe rated 600V CAT III. It blew apart, with flash damage on the safety case we test the unit in. It also kicked and broke the clamp that held it in place.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Offline Kiriakos-GR
  • Banned!
  • Country: gr
  • User is banned.
Re: EEVblog #84
« Reply #29 on: May 08, 2010, 04:27:32 am »
About the mains plug in the wall , light switches , and all sort of parts ...
I have never seen  anyone from the manufacturers , to comply in anything as CAT standards.
What I am trying to say are , that even if any multimeter can pass ( or survive ) CAT testing,
the  220V installation will fall down first from an extreme over-voltage .
The weakest part in the link , as an cheap wall plug , of bulb holder , it will become toasted , even before the multimeter comes close to the maximum CAT rating as device.
Are we a bit overreacting in this CAT limits ?
Offline jahonen
Re: EEVblog #84
« Reply #30 on: May 08, 2010, 04:42:15 am »
Multimeter is (could be) hand-held device, plugs and switches on the wall are not. Thus the safety requirements.
Regards,
Janne
alm
  • Guest
Re: EEVblog #84
« Reply #31 on: May 08, 2010, 04:43:58 am »
One difference between a lamp socket and a multimeter is that you often hold the DMM in your hands, something you rarely do with a lamp. And mains equipment can be certified (eg. UL/TUV, often required by insurance) and does have to comply to regulations (NEC in the US), although I've no idea what actually means compared to IEC 61010. Plus the fact that you are measuring something often means that something is wrong/changed.
Transients are (at least in this part of the world) a rare occurrence, but it would suck if a multimeter blew up in your face, even if it's only once. It's kinda like seat belts in a car: cars don't usually collide, but if something happens, it's nice to not have your face smash into the windshield. It's not the probability, but the severity. But the lower the energy levels and the less you use it, the lower the risk (as in probability * severity), so at some point, the risk becomes low enough that it's not worth worrying about.
« Last Edit: May 08, 2010, 05:29:17 am by alm »
Online Simon
  • Global Moderator
    • Simon's Electronics
Re: EEVblog #84
« Reply #32 on: May 08, 2010, 04:47:02 am »
no if greek wiring standard are anything like the italian ones i experienced I'm hardly surprised  ;D
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
Offline Kiriakos-GR
  • Banned!
  • Country: gr
  • User is banned.
Re: EEVblog #84
« Reply #33 on: May 08, 2010, 07:17:52 am »
Ok, I agree too with this point of view ..
Now , about the "hand held" risky devices, we should pass from CAT testing all the mobile phones too,
some of them does blow at your face .. or so  ;D
Offline Kiriakos-GR
  • Banned!
  • Country: gr
  • User is banned.
Re: EEVblog #84
« Reply #34 on: May 08, 2010, 07:20:54 am »
no if Greek wiring standard are anything like the Italian ones i experienced I'm hardly surprised  ;D
Nag and Dance as much you like, me and my European brothers , we are fearless ..
We eat cables and spit sparks for breakfast ..  :P
Offline jahonen
Re: EEVblog #84
« Reply #35 on: May 08, 2010, 04:08:49 pm »
There are relevant safety standards regarding the mobile phones too. Any 230 VAC mains connected device must have an isolation which can withstand at least something like 2-3 kV between mains input (for some time, say 1 minute) and user touchable conducting part. So mobile phone charger must also withstand that. You have probably heard about exploding fake mobile phone batteries, so even with no mains at all, there are safety issues.
What is wrong with having a product safety? That is one parameter which should not be compromised, ever.
Regards,
Janne
« Last Edit: May 08, 2010, 04:11:47 pm by jahonen »
Offline Kiriakos-GR
  • Banned!
  • Country: gr
  • User is banned.
Re: EEVblog #84
« Reply #36 on: May 09, 2010, 12:12:59 am »
Regards,
Janne
The wrong its not the device it self , its the consortium of the few who had create the high standards,
and try to dominate the market , by blaming any one who is not part of it.
If you sell safety , then everything else than yours , it must be baptized unsafe , so to make money just from that.
Or every medium scale manufacturer , he has to pay the price in the consortium, so his products to be baptized as safe too.
I do not know if you understand my point , but looks that the high safety standards ,
to be just a merchandise .
So I am equally skeptic and for the cheap PRC  made product ... and for Mister Fluke , the safety seller.
And I truly need from one True electronics engineer , to take apart one Fluke 87 and evaluate the cost of the inner parts .... I need to know where my money goes ..
Offline Kiriakos-GR
  • Banned!
  • Country: gr
  • User is banned.
Re: EEVblog #84
« Reply #37 on: May 09, 2010, 03:11:47 am »
Digital cameras Flash unit as CAT tester ... not bad idea   ;D
My Olympus FL-40 have even adjustable output to 40 steps .... But costs too much to become as DMM CAT tester ..   ;)
Pradipta
  • Guest
Re: EEVblog #84
« Reply #38 on: May 09, 2010, 04:42:36 am »
Men, I do not think it to be a bright idea, but we can acid test our own instrument with a car ignition coil (for all petrol engines). Connect the primary of the ignition coil to the secondary of a high power (Volt-Ampere) or high current (2 Ampere is a good compromise) rated 12 Volt mains transformer (the primary of the mains transformer being connected to the wall output). I apprehend the secondary of the ignition coil to be at greater than 1000V.
I could tell the difference between a Made in Taiwan R.O.C. multimeter and a Made in USA Fluke. No not a splendid display of fireworks I suppose but a conclusive boundary line drawn to indicate the maximum voltage tolerated by a multimeter without running out of operation (use 6V, 9V, 12V, 15V rated transformer in steps).
« Last Edit: May 09, 2010, 04:45:12 am by Prad »
Online Simon
  • Global Moderator
Re: EEVblog #84
« Reply #39 on: May 09, 2010, 05:51:48 am »
the voltage will not vary the time the flash lasts will vary, photography is albout exsposure time.
I don't know about Greece but in Italy, statisticly 4.5 people a day are killed at work. now i know many of these are building site accidents (like a crane collapsing because it was used until it rusted) and the odd farmer falling into his own well and drowing but it shows the general attitude of some countries to safety. True being over saftey concious can ruin things but buying a £5 meter knowing that the CAT rating on it is probably a fake is not clever.
Online Simon
  • Global Moderator
Re: EEVblog #84
« Reply #40 on: May 09, 2010, 06:59:25 am »
well of the three cheap meter dave tested one actually blew apart and the other bulged and emited flames (for an instant), normally you would not encounter 4 Kv but it does show just what a difference lack of protection in cheap meters can make
Offline Kiriakos-GR
  • Banned!
  • Country: gr
  • User is banned.
Re: EEVblog #84
« Reply #41 on: May 09, 2010, 09:22:42 am »
We prefer to get killed in holidays and weekends with our cars , its more fun this way  ;D
About the flash unit , what this Australian guy had made , its a flash unit in a large scale,
and nothing more ..
« Last Edit: May 09, 2010, 09:27:19 am by Kiriakos-GR »
Offline saturation
  • Doveryai, no proveryai
    • NIST
Re: EEVblog #84
« Reply #42 on: May 13, 2010, 01:09:01 am »
Yes, I think the bottom line in CAT ratings is safety, not survivability of the device.
One important parameter that is omitted from the above table is the source impedance, which determines how much current the source will be able to deliver, i.e. the size of the bang if something shorts/arcs. This is the important difference between CAT I and CAT IV. Compare touching the HV electrode of a large CRT (with 30kV acceleration voltage) with touching a 33kV high-voltage transmission line. The former will hurt but probably not kill you (most of the danger is actually from the muscle reaction, not the current), the latter might actually cook or vaporize you. The former is CAT I, the latter is CAT IV. This is why CAT I tests are conducted with a 30ohm source impedance (peak short circuit current for CAT I 600V is 2500V/30ohm = ~83A), and CAT IV with a 2ohm source impedance (peak short circuit current for CAT IV 600V is 8000V/2ohm = 4000A).
I believe IEC 1010 only requires that the equipment should not be dangerous to the user (explode or catch fire), not that it keeps working.
CAT I 300V on your scope means that it's rated for up to 300V on CAT I (i.e. residential/office equipment on the secondary side of the power supply), so 110V (or 230V) mains is outside the specification. So it actually means more than just '300V max'.
Best Wishes,
 Saturation
Offline saturation
    • NIST
Re: EEVblog #84
« Reply #43 on: May 13, 2010, 01:10:39 am »
I'd like to see close ups of the damaged areas.
Also, its well known those glass fuses are inadequate for transients, how did they fair in the cheap DMMs?
What happened to any HRC and SIPA fuses, did they blow too?
Yeah, that was fun. Shame Doug only had the baby 400J unit, we were hoping to see a meter catch on fire. But we did get one to fully explode which was pretty cool.
Next video is a quick explaination from Doug about building a high voltage probe.
Dave.
Best Wishes,
 Saturation
