Author Topic: EEVblog #847 - Mailbag  (Read 16152 times)
Offline EEVblog
« on: February 03, 2016, 07:55:32 am »
Mailbag. Dave opens his mail and tears down a bunch of random stuff.
Other Youtubers:
http://www.youtube.com/user/DextersLab2013
http://www.youtube.com/user/CarlsTechShed
SPOILERS:
Counterfeit copies of Art Of Electronics!
Genuine copy is here:
http://amzn.to/1nCmmaK
How to detect the counterfeits: http://artofelectronics.net/the-book/counterfeit-editions/
Electromechanical vibrator from a chopper amplifier
Polygraph machine amplifier teardown
Fluke 70 teardown
RCA valve oscilloscope teardown
Analog Discovery 2
http://store.digilentinc.com/analog-discovery-2-100msps-usb-oscilloscope-logic-analyzer-and-variable-power-supply/
Red Pitaya V1.1 Digital Measurement & Control Development Board
http://redpitaya.com/
Home energy Saver device teardown
Guest appearance by Sagan
« Last Edit: February 03, 2016, 12:04:14 pm by EEVblog »
Online Falkra
Re: EEVblog #847 - Mailbag
« Reply #1 on: February 03, 2016, 08:28:03 am »
Nice close up shots, it's not blurred anymore. Nice.  ;D
Great teardowns, great selection of objects, great to watch !  :clap:
« Last Edit: February 03, 2016, 08:31:41 am by Falkra »
Offline daqq
  • Country: sk
    • My site
« Reply #2 on: February 03, 2016, 09:04:15 am »
Nice mailbag Dave!
I noticed a funny thing on the chopper - dendrites! See attachment.
Offline cezar
« Reply #3 on: February 03, 2016, 10:30:04 am »
Red Pitaya is indeed an interesting device. it can do a 0-50MHz SDR Transceiver! No mention of scope, signal generator and many, many others
Offline gadget73
« Reply #4 on: February 03, 2016, 10:36:14 am »
I'd be very interested in seeing a comparison of the two USB scopes.  I've given a bit of thought to replacing or at least supplementing my old CRT scope with a USB one, and seeing some of the various options compared would be helpful.  I like my old CRO fine and all, but once in a while it would be really nice to have direct frequency or voltage readings, or be able to easily snag a graphic of output without trying to take a picture of the screen.
Offline dexters_lab
    • DextersLab2013
« Reply #5 on: February 03, 2016, 10:42:20 am »
Nice mailbag Dave!
yea, i saw that too... tin whiskers!
the one i took apart had none that i noticed
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." - Douglas Adams
http://dexterslab2013.blogspot.co.uk/
Offline fubar.gr
  • Country: gr
    • Fubar.gr
« Reply #6 on: February 03, 2016, 11:57:46 am »
There was a cap (or was that a MOV?) that looked like split in half in that Fluke multimeter.
« Last Edit: February 03, 2016, 11:59:40 am by fubar.gr »
Offline EEVblog
« Reply #7 on: February 03, 2016, 12:05:22 pm »
Are there any other directly competing ones? Not talking no-name ebay ones.
Offline gadget73
« Reply #8 on: February 03, 2016, 12:34:03 pm »
Only thing I know about USB scopes is they have USB :)  Its an area I've done precisely zero research on.  I just find the notion of being able to see a display on my 32" LCD monitor with software analysis and data readings right on the screen to be interesting.  I don't know if one would do for me though.  I mess with tubes for audio and radio work mostly, so RF and high voltages would have to be something it does.
Offline HAL-42b
« Reply #9 on: February 03, 2016, 01:57:24 pm »
That polygraph is obviously designed to intimidate with it's sciency look more than anything  :-DD
Also it was fun watching Sagan learn the word Scam.
Offline AF6LJ
« Reply #10 on: February 03, 2016, 02:51:33 pm »
Good Stuff.
Sue AF6LJ
Test Equipment Addict, And Proud Of It.
Offline mtdoc
« Reply #11 on: February 03, 2016, 02:54:19 pm »
In addition to making polygraghs, Grass Instruments has been a high quality maufacturer of nerve stimulators used in research and teaching labs since the 1960s. I recently bought one of their classic SD9 stimulators on eBay. It's fully isolated, so safe to use with human subjects. It has a well engineered modular design.
« Last Edit: February 03, 2016, 04:24:39 pm by mtdoc »
Offline scopeman
« Reply #12 on: February 03, 2016, 03:54:30 pm »
Hi Dave,
Great mailbag. The Fluke 73/75/77 are great meters. My dad gave me a box full of mistreated and dodgy ones years ago.
Usually a cleaning some Caig DeOxit on the switch and a new battery fixed them up.
At one time it cost more to have them calibrated a few times than buying new meters so many tossed them and bought new.
The only real problem is the zebra strip connection to the display. It appears that yours may have that problem. Just clean the strip and the display and the PCB to zebra connections with alcohol and put it back together and it will still be good until Sagen gets to college. If you put one of those 9V lithium batteries in the meter it will probably still be ready to use when he starts his first circuits lab around 2030 or so. Earlier if he skips a grade!
Those meters were shipped with the carbon zinc 9V batteries IIRC. They would run the meter for 2000+ hours no problem. I think that is what I liked best about them as well as their phenomenal Fluke stability. Rare to see the CZ 9V battery leak. Alkalines do! I believe that lithiums do not. You can find them in the big box hardware stores as they are used for smoke and CO detectors.
For the person that was asking about the slot in the MOV. This was standard practice to cut a slot to create a spark gap. That could be just a capacitor with a spark gap cut. These work to ground the zaps just like the old Frankenstein movies.
The case screw design is called Plastite(R). It is a dual helix screw designed especially for plastics. A patented design that costs more than the average screw. The hint to keeping the threads in the plastic case is to drop the screw in and rotate it counter-clockwise ( it is CCW in Oz is it not?) until the screw drops into the thread, then turn clockwise to tighten. I do not remember having any units with stripped threads. However I have seen some with broken stops for the rotary switch. A cure for that is to pop the actuator off of the housing and use a pin vise to drill a small hole where the broken stop was. Then use the cut head off of a small finishing nail (you need to retain part of the shank) to create a new stop. Simply heat the pin with a soldering iron at a low temperature until it sinks into the plastic while guiding it into the hole. Once cooled you will have a new stop.
Overall the 75/77 is one of the finest and simple meter designs out there.
Something Sagan will appreciate when Dad is old and grey!
Sam
W3OHM
Owner and Moderator of the independent LeCroy_Owners_Group on Yahoo! Groups
Offline mtdoc
« Reply #13 on: February 03, 2016, 04:28:10 pm »
Dave,
Yes, please do a comparison of the Analog Discovery and the Red Pitaya - including the software!  These are much more than just USB scopes as you know.
Also - a side by side teardown comparison of the Analog Discovery 2 with the original AD if you still have it.  I believe the only major hardware difference is the addition of the external power input to provide more power for the 5V power supply - but it would be good to see that confirmed - and see what other changes they may have made to the layout.
Offline Stonent
« Reply #14 on: February 03, 2016, 07:00:32 pm »
I noticed these things:
Online Yansi
  • STM32, STM8, AVR, 8051
« Reply #15 on: February 03, 2016, 09:15:24 pm »
Spark gap
Offline dexters_lab
    • DextersLab2013
« Reply #16 on: February 03, 2016, 10:10:49 pm »
 :-+ i hear the stimulators are quite sought after
Offline EEVblog
« Reply #17 on: February 03, 2016, 10:18:44 pm »
Yep. totally missed that.
Offline DuraAce
« Reply #18 on: February 04, 2016, 06:37:16 am »
Dave, it looks like your investigation of the solar panel caused too much UV radiation and lead to a sunburn  :-DD :box: or was it the beach.  O0
« Last Edit: February 04, 2016, 06:39:16 am by DuraAce »
Offline KenGaler
    • Innovative Electronics LLC
« Reply #19 on: February 04, 2016, 07:25:01 am »
I'd like to see a comparison between the Analog Discovery and the Red Pitaya also.
I just bought the Red Pitaya fm Mouser but as it turns out the hardware is NOT open sourced, just the software.  You can't get a schematic.
Ken
« Reply #20 on: February 04, 2016, 12:25:51 pm »
I had one of the Sinclair Cambridge calculators in around '72 or '73.
There were two versions, the regular four function one with an equals key and the 'Scientific' which had trig. functions and was RPN. Both came as either assembled and ready to go, or as a solder it yourself kit for a couple of pounds less. You can probably guess that I had the Scientific in kit form.
Ian
Offline Len
« Reply #21 on: February 04, 2016, 12:57:13 pm »
So did I. I felt quite a pang of nostalgia seeing one here.
Online Fungus
« Reply #22 on: February 04, 2016, 04:38:25 pm »
Very interesting: http://righto.com/sinclair
Offline Brumby
« Reply #23 on: February 04, 2016, 05:10:09 pm »
That was interesting.  Thank you!
Online Fungus
« Reply #24 on: February 04, 2016, 05:22:14 pm »
Also: http://www.datamath.net/Manuals_Others/Sinclair_Scientific_GB.pdf
Quote: "...it is a substitute for slide rules and mathematical tables."
So while everybody else was trying to produce 8 or 10-digit accuracy, Sinclair was aiming at people who were used to working with slide rules and log tables.
Smart move. The accuracy and limited range of the math functions wouldn't be a problem for those people and the price would be very attractive (50 pounds for the Sinclair instead of 300-400 pounds for HP/TI, according to some pages I've seen).
« Last Edit: February 04, 2016, 07:50:20 pm by Fungus »
