We used to take apart the old Mirage autopiloys out of airframed being upgraded, as they contained the right selection of gears, synchros, resolvers and such needed to fix other avionics. Basically a big brass meccano set with all the various plates doing assorted functions. The dead ones still were usable even if the coils or contacts were burnt out, I used to gently strip them to get the bearings out, along with the stator coils on some, to fix cooling fans that were faulty. Sealed, epoxied together assemblies, but with a little determination you could take it apart and use the certified parts again. Everything had a part number and serial number on it, even the individual gears, and in some cases even the rotor and stator of a resolver.
Did send GK a nice little sine/cosine pot for him to use, he probably has more use for this, relic from some auction scrap medical research equipment.
