Author Topic: EEVblog #857 - High Speed Camera Fun  (Read 19398 times)
Offline EEVblogTopic starter
« on: March 04, 2016, 10:52:55 pm »
Dave plays with his new Sony RX100 Mk4 high speed camera that can shoot 1000fps.
Blowing up capacitors, fuses, and LED's.
And what does a multiplexed VFD display look like?
Offline photon
Re: EEVblog #857 - High Speed Camera Fun
« Reply #1 on: March 04, 2016, 11:54:18 pm »
Beauty.
Offline hopski
« Reply #2 on: March 05, 2016, 12:11:14 am »
Tasty. Some of those older electrolytics with no vents do tend to go with a good bang.
I've done a few "accidentally"    >:D >:D
« Last Edit: March 05, 2016, 12:18:07 am by hopski »
Offline nctnico
« Reply #3 on: March 05, 2016, 12:46:24 am »
This video reminds me of this guy making stills of all kinds of rapidly moving objects and splashes using self build circuits:
https://www.flickr.com/photos/fotoopa_hs/albums
Offline nidlaX
« Reply #4 on: March 05, 2016, 01:06:17 am »
The RX100 IV is a beast of modern engineering. Sensor and processing tech consumers couldn't even dream up 5 years ago.
Offline strangersound
  • Resistance Is Not Futile
« Reply #5 on: March 05, 2016, 01:23:48 am »
The multiplexed VFD was definitely cool. :)
It is amazing what the average guy can get his hands on these days. I'm still amazed at what my Lumix can do and it's already old news now. :)
"I learned a long time ago that reality was much weirder than anyone's imagination." - Hunter S. Thompson
« Reply #6 on: March 05, 2016, 01:52:43 am »
It's still no where near enough for shooting most things.
Explosions for example are not much good at 1000fps, it's basically there one frame and gone the next.
At least for small scale. Big scale mythbusters style it's enough.
« Last Edit: March 05, 2016, 02:09:02 am by EEVblog »
Offline nidlaX
« Reply #7 on: March 05, 2016, 02:03:18 am »
Yeah! Are you thinking of what happened in Mike's latest video with the GFCIs? If you're gonna risk blowing yourself up, better get a camera that can grab the moment!
Offline pickle9000
« Reply #8 on: March 05, 2016, 03:14:23 am »
Chinese multimeter and a brick.
Offline Georgitsu
« Reply #9 on: March 05, 2016, 06:40:04 am »
Cool! I love seeing the fuse filament ball up at its end where it melted.
Couldn't help but notice the bright sunny day as he blew up the caps outside. We're still wintering over here in the states.
Offline 6581
« Reply #10 on: March 05, 2016, 07:17:37 am »
I don't like seeing anything useful smashed to pieces. But hopefully the brick will survive just fine.
Offline pickle9000
« Reply #11 on: March 05, 2016, 07:22:32 am »
I love bricks.
Offline fantis1337
  • Country: is
« Reply #12 on: March 05, 2016, 08:24:57 am »
Someone should make a hour long high fps video of caps blowing up with some meditation music in the background. Found that oddly relaxing.
If you run into an asshole in the morning, you ran into an asshole.
If you run into assholes all day, you’re the asshole.
Offline German_EE
« Reply #13 on: March 05, 2016, 10:40:31 am »
Head over to https://www.youtube.com/user/RODALCO2007 where 90% of the content is stuff being blown up. Not my taste but YMMV.
Warren Buffett
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #14 on: March 05, 2016, 10:50:21 am »
Does the Sony have a post or mid-trigger mode so you can stop it after the event?
Day Job: Mostly LEDs
Offline BobC
« Reply #15 on: March 05, 2016, 07:05:33 pm »
In 2000 I was working at a high-speed industrial camera company on a team to build an extremely ambitious device: A camera that could take video at 100,000 frames per second while being subjected to 100G forces.  We wanted to eliminate film from the industrial market, where so-called "streak" cameras could have frame rates up to 1,000,000 frames per second (most famously used to record nuclear bomb tests).
Being an embedded real-time software engineer, my job was to define and implement the interface layer between the low-level camera hardware and the external high-level user interface.  The camera hardware was a fiercely complex dynamic state machine, while the user interface exposed many controls that could easily interfere with each other (the range of paramater X depended on the settings of parameters Y and Z, each of which depended on A, B and C).
My solution was to get the hardware engineers to implement a "what if" capability, where the camera would return an error rather than silently accept an invalid setting.  This capability allowed both the low-level hardware and the user interface to evolve almost independently, while my middle-layer tracked two whole-camera states: The last successful configuration, and the last unsuccessful configuration, where the differences were made available to the UI.
But who cares about software?
When our first all-up alpha camera was built (electrically correct, but quite unable to fit in the final enclosure), the first high-speed video run (at 85K fps) produced all black frames when pointed out the window at a brightly sun-lit outdoor scene.  The hardware folks were going crazy, thinking we had failed to correctly read the pixels from our custom sensor.
I sat back and did the math, calculating the number of photons needed to reach half-exposure on a pixel, then dividing by the exposure time to get the required flux.  That flux level was enormous.  About 30% of what pointing the camera directly at a full-field view of the sun would yield.  Something we were not about to do, since we didn't want to melt the sensor in our first working prototype.
But what other bright light source could we use?  In our conference room was an early DLP video projector that used a high-pressure gas-discharge tube mounted behind an IR filter.  We aimed the camera through the filter and directly imaged the arc in the lamp, clearly showing how it danced within the confines of the bulb.
We immediately posted the video to our website, and just a few days later the US President of a Very Large Japanese projector manufacturer called, wanting to see our prototype camera in action.
It turns out that this 'arc wander' was a serious problem for projector manufacturers, since it meant the optical focus had to encompass the entire arc volume, rather than just a central portion.  In many projectors of the day, this effect was visible in the projected image as a quiver or shake leading to a soft-defocus effect.  One corrective approach had been to make the bulbs smaller, but that made it much more difficult to remove the generated heat, leading to greatly reduced bulb life.
By the time the Japanese delegation arrived, we had the first of three beta units built.  We repeated our experiment for them, using bulbs they had brought with them.  On the spot, they offered us an insane price for one of our beta units, wanting to leave with it that day.  We made them wait until all three beta units were ready, then sold them one.
The beta units did fit in the final enclosure, but they didn't come close to meeting the 100G impact requirements.  Why would any camera need to survive 100G treatment?  That's more than enough force to tear any lens right off the front of the camera.  Our design goal was for our camera to survive a lifetime of such impacts without affecting normal operation (aside from having to replace the lens).
Our camera had two main customers: First was the auto crash test industry, where they needed cameras to be inside cars during high-speed crashes.  The second was military weapons testing, where the closer the camera could be to the blast, the better the video would be.
Once such high-speed video was available, some of the spin-off uses surprised us.  For example, one customer used our video to greatly improve the state-of-the-art in Finite Element Analysis of structures, improving their analytical techniques until the simulation of an impact precisely matched the actual deformation captured by our cameras.
Unfortunately, the development costs for this camera bankrupted the company: The expected pre-orders failed to appear (there was a recession at the time), while our lines of credit became too expensive to afford.  The company was sold to a competitor for a song, and the entire engineering team was laid-off just weeks after the camera work was completed.
« Last Edit: March 05, 2016, 07:11:42 pm by BobC »
Offline halexa
« Reply #16 on: March 05, 2016, 08:15:35 pm »
Hey Dave,
Time to revisit the sparkgap video in high speed.
Offline electr_peter
  • Country: lt
« Reply #17 on: March 05, 2016, 10:31:41 pm »
I have considered to buy Sony RX100 Mk4 for it's high speed capture capabilities but did not do it after all.
I thought about my needs and found 1000 fps to be not good enough, because:
  • 1000 fps (= 40 * 25 fps) is only 40 times faster than normal playback - it is not enough to capture more interesting events invisible to a naked eye. 400-1000 times or faster (10000-25000 fps) would be more suitable
  • 1000 fps mode is limited in resolution/recording speed/lighting conditions/focusing/frame size/... Special setup with lighting and some sort of quick triggering mechanism is needed to use short memory - not that trivial with this camera.
  • Sony RX100 Mk4 is a great camera, but it is very expensive if 1000 fps option is not used/usefull for you.
Offline joeqsmith
« Reply #18 on: March 05, 2016, 11:40:49 pm »
It can buffer up the data so when you press the record it stores everything prior to that.  You can also trigger before the event.
Video showing the external trigger I modified for it to except a standard 50 ohm source.
Spark plug with Sony
https://www.youtube.com/watch?feature=player_detailpage&v=RZJJQVxvceM#t=93
« Reply #19 on: March 06, 2016, 12:55:09 am »
i found it has a stop trigger mode, but haven't tried it yet.
Annoyingly the remote WiFi trigger app doesn't work in HFR mode  :palm:
So you have to press the annoying little fiddling stop button on the camera.
« Reply #20 on: March 06, 2016, 12:56:32 am »
Yep, I'll try that.
Offline McBryce
« Reply #21 on: March 06, 2016, 01:53:00 pm »
Try watching solder paste in the moment the tiny spheres turn to liquid. Really cool if you can get the magnification and slow-motion.
McBryce.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #22 on: March 07, 2016, 03:01:30 am »
Great video, Dave. Perhaps a tantalum capacitor would also be interesting as it would go down in flames or with a *BANG!*
That Sony is a beauty, alright. Would love to have one.
 Mythbuster-level, however, is another league: yesterday I watched one of Mythbusters' episodes of their last season, and they were using a 28k fps full HD camera!
Offline 67mustang-man
« Reply #23 on: March 07, 2016, 08:45:31 pm »
I have a power supply similar as that one, Branded Tenma, I do often wonder how well they are built. Great video! :-+
Offline lemming
  • A Lemming is as Lemming Does
    • HSBNE
« Reply #24 on: March 15, 2016, 11:12:51 am »
Hi All,
I have been looking at this camera as I have an earlier one (Nikon 1 AW1) that does 400 fps and 1200 fps, but the resolution is pretty tiny.
What might interest you guys though is what we use it with....
http://imgur.com/a/gZZCY
The better it felt when you said it, the more likely it is to get you in trouble.
IRC is just multi-player Notepad.
