Author Topic: EEVblog #884 - EEVBlog BM235 Multimeter REPAIR - multimeter cable  (Read 1047 times)
Offline try
  • Metrology from waste
« on: September 28, 2016, 02:21:19 am »
Hi Dave,
when watching that episode I discovered that you were using cables with the well-known Multicontact plugs.
Did you configure your cables yourself with those plugs or did you buy the cable as a complete set?
I am just wondering if your cables exhibit only low thermal voltages...
Regards
try
