While on the topic of scopes like this, for the price they charge, the least they could do is include a top of the line CPU and GPU, along with some liquid cooling in order to handle a decent overclock. The screen should be 4K 120hz with 100% adobe RGB coverage, and it should have at least 128GB of RAM in order to also handle other useful applications such as maya and adobe premiere.
They should also give it larger 120mm-140mm fans for lower noise levels, and the buttons and allow for RGB color choices.
Or if needed, liquid cool the entire system with a custom loop leading to 2 420mm radiators, that way one side or the top can have 6 140mm fans that can run at a low speed to keep things quiet.. The other side can then get tempered glass side panels to show off the RGB case lighting.
