Author Topic: EEVblog Electronics Community Forum empty post  (Read 24746 times)
Online ataradov
    • Personal site
Re: EEVblog Electronics Community Forum empty post
« Reply #50 on: October 30, 2015, 01:32:48 am »
Works with GreaseMonkey under FF too.
Alex
Offline crispy_tofu
« Reply #51 on: October 30, 2015, 01:40:34 am »
Online EEVblog
« Reply #52 on: October 30, 2015, 01:46:59 am »
I don't mind the one as a header to any page, but the one as a footer is just.......visual pollution.  :--
There has always been that exact same ad in the footer.
It's just now in the last post instead of the very bottom.
I'm just playing around with some ad settings.
Online EEVblog
« Reply #53 on: October 30, 2015, 01:48:10 am »
I prefer the footer.  You can ignore it by not scrolling down that far.  The header ad is always in your face.
Yet no one has complained about the (huge) header ad for about 4 years now  ;D
Online Monkeh
« Reply #54 on: October 30, 2015, 01:49:42 am »
I haven't seen it in 4 years!
Soon as an ad affects my usage of a site it goes away. Wasting the limited vertical space on modern monitors is a prime example of affecting usage.
Online EEVblog
« Reply #55 on: October 30, 2015, 01:50:29 am »
It looks more like a script went cactus on the eevblog forum server ...but I could be wrong...I was once :)
No, there are many options for ad placement on the forum:
Online Monkeh
« Reply #56 on: October 30, 2015, 01:51:56 am »
Is the 'welcome user area' by any chance the immense empty space at the top of every single page? Because that's a great place to put ads.
Online EEVblog
« Reply #57 on: October 30, 2015, 01:54:38 am »
Also, have not Dave just bragged that his AdSense revenue increased a lot. Is this a way to capitalize on this increase?
No, it's the exact same ad I had there before at the bottom of the page. I'm just playing around with the ad placement settings.
Offline c4757p
  • adieu
« Reply #58 on: October 30, 2015, 01:59:14 am »
The header ad doesn't interrupt the page. This one is between things. That's just bad design.
Offline ez24
  • L.D.A.
« Reply #59 on: October 30, 2015, 02:00:18 am »
Drive um crazy - check ALL the options  :-+  (for one day  :-DD )
« Last Edit: October 30, 2015, 02:02:51 am by ez24 »
Online EEVblog
« Reply #60 on: October 30, 2015, 02:01:17 am »
The thought had crossed my mind, I do like watching people's heads explode  >:D
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #61 on: October 30, 2015, 02:02:43 am »
Do it once for about 5 minutes!  :-DD
Online Monkeh
« Reply #62 on: October 30, 2015, 02:03:01 am »
Offline crispy_tofu
« Reply #63 on: October 30, 2015, 02:07:38 am »
Online edpalmer42
« Reply #64 on: October 30, 2015, 03:57:12 am »
I wouldn't complain about it because I realize it's how you make money, the ads are appropriate for the site, and I feel a bit guilty about blocking them  :-[ .  I can't figure out how to allow supplyframe.com on eevblog but block it elsewhere.
Ed
Offline BravoV
  • +++ ATH1
« Reply #65 on: October 30, 2015, 04:13:41 am »
If you have TamperMonkey in Chrome (proabably GreaseMonkey in FF works too, untested), hit below to install a user script to remove that annoying last post.
No warranty expressed or implied :)
https://gist.github.com/sleemanj/84e15fda23f79a7852b6/raw/eevblog-no-annoyance.user.js
Fyi, looks like its turned off by Dave just now, and this script will make the last legit post disappear.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #66 on: October 30, 2015, 04:51:45 am »
BECAUSE IT DOESN'T INTERRUPT THE FUCKING READING
Seven Transistor Labs, LLC
Online EEVblog
« Reply #67 on: October 30, 2015, 04:56:17 am »
BECAUSE IT DOESN'T INTERRUPT THE ******* READING
Sure it does, you have to scroll down before you start reading. It's just that everyone got used to it.
BTW, try not to swear and SHOUT. People tend to take you less seriously.
« Reply #68 on: October 30, 2015, 05:11:14 am »
Ads within the top and bottom limits of the forum page affect user flow, without those ads all the buttons/links are easily accessable without interuption from the ads. I use the links and shortcuts both top and bottom and when the ads are outside the user's area it makes for a better flow.
The footer ad that was there this morning definately did the job it was intended to....it was in your face and we may not have bitched so much IF it was electronic related.
You have to make a living Dave, do as you must.
Avid Rabid Hobbyist
Online T3sl4co1l
« Reply #69 on: October 30, 2015, 06:50:01 am »
Ahh, it's readable again, thanks Dave!
Offline hamdi.tnTopic starter
  • Country: tn
« Reply #70 on: October 30, 2015, 07:31:12 am »
:clap: thanks Dave.
that last post ad was like a smashed bug in a windshield you know  :palm:
Online sleemanj
  • Professional tightwad.
« Reply #71 on: October 30, 2015, 08:21:51 am »
In theory I made it check the poster's name to be sure it was the annoy-o-tron in action, in practice 20 years of C-like languages and you'd think I'd be able to reliably type == instead of =  |O
Offline crispy_tofu
« Reply #72 on: October 30, 2015, 08:33:13 am »
Thanks Dave!  :-+
Offline Mr.B
« Reply #73 on: October 30, 2015, 08:34:36 am »
... in practice 20 years of C-like languages and you'd think I'd be able to reliably type == instead of =  |O
Happens to all of us... LOL...
Even after the same amount of time I sometimes forget the semicolon... I curse myself because it should simply be habit.
I approach the thinking of all of my posts using AI in the first instance. (Awkward Irregularity)
Offline Macbeth
« Reply #74 on: October 30, 2015, 03:38:11 pm »
Those pesky varmints get me too often.  :-DD At least the semicolon is usually alerted by the compiler, the = vs == usually ends up in your released code, usually somewhere obscure and doesn't show even after thorough testing. Like I think in this case (an external change showed it up).
