Author Topic: Heat Sink Question  (Read 2145 times)
Offline KeithTopic starter
Heat Sink Question
« on: September 20, 2011, 05:29:21 pm »
I just purchased a few Heat Sink mounting kits that come with the hardware and an insulator to support a TO-220 mount. My question is do I need to purchase and apply a heat sink compound to this assembly or is the mounting kit and insulator sufficient? Thanks.....
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
Re: Heat Sink Question
« Reply #1 on: September 20, 2011, 07:37:37 pm »
Usually I add thermal compound in the back plate of the transistor and at the heat sing.
The existence of the insulator plate does not change anything.
alm
  • Guest
« Reply #2 on: September 20, 2011, 08:01:57 pm »
Depends on the type of insulation. Hard stuff like mica needs thermal grease to fill all voids, the soft silpads can be deformed and will do most of the work themselves, although I guess a tiny amount of thermal grease wouldn't hurt. Thermal grease is necessary to displace any air that's inevitably present between two hard surfaces that are not perfectly flat, but copper or aluminum conduct much better, so always use thermal compound sparingly.
