Author Topic: EEVblog#160 – 555 Timer Easter Egg?  (Read 15242 times)
Offline AdShea
Re: EEVblog#160 – 555 Timer Easter Egg?
« Reply #25 on: April 03, 2011, 01:28:53 pm »
Are you putting the signal in through the power supply?
Offline Lance
  • Resistance if futile if R<1Ohm
« Reply #26 on: April 03, 2011, 03:37:39 pm »
I posted this in another forum...the response is skeptical.
http://www.physicsforums.com/showthread.php?p=3226304#post3226304
#include "main.h"
#include <pic.h>
//#include <killallhumans.h>
Offline ShiftPlusOne
« Reply #27 on: April 03, 2011, 03:52:31 pm »
Doesn't seem they are being skeptical as much as they are just being asshats.
Offline firewalker
  • Country: gr
« Reply #28 on: April 03, 2011, 06:06:02 pm »
Dave used batteries also.
Offline FreeThinker
  • Truth through Thought
« Reply #29 on: April 03, 2011, 06:35:28 pm »
Take a look Here
Machines were mice and Men were lions once upon a time, but now that it's the opposite it's twice upon a time.
MOONDOG
Offline neoone
« Reply #30 on: April 03, 2011, 07:25:44 pm »
Could you explain some things? Are you saying there is not only 55.5kHz but also it's harmonics at 111kHz ? sorry but I couldn't understand few words on your video probably due to accent ;) Or maybe you wanted to show Us that there is something injected to the signal through a ground loop of the probes ?
Offline FreeThinker
« Reply #31 on: April 03, 2011, 07:28:23 pm »
It's not my video  :) Just found it on YouTube.
MOONDOG
Offline neoone
« Reply #32 on: April 03, 2011, 07:56:42 pm »
oh, OK :) Any ideas then ?
Offline FreeThinker
« Reply #33 on: April 03, 2011, 08:41:48 pm »
As I understand it he says that it also modulates at 111hz at 111khz carrier ie twice Daves frequency. 55khz could be the fundamental frequency or another harmonic, still not convinced that there isn't some sneaky business going on but it's beyond me, just have to wait for Dave to come clean or someone to crack it........watch this space ;)
MOONDOG
Offline tnt
« Reply #34 on: April 03, 2011, 08:48:14 pm »
Quote from the video author found on youbtube :
If he has done it like me, than there is a hidden wire to the control voltage pin, from an external sine generator, adjusting the level with another? pot outside the camera view. Of course, if you add a capacitor from this input to ground, the modulating signal will be shorted :-)
Offline FreeThinker
« Reply #35 on: April 04, 2011, 12:07:28 am »
Perhaps Daves April Fool will get to be as famous as this
http://news.bbc.co.uk/onthisday/hi/dates/stories/april/1/newsid_2819000/2819261.stm
MOONDOG
Offline Zero999
  • Hero999
« Reply #36 on: April 04, 2011, 01:36:01 am »
That makes sense, so it/s not just the frequency which changes, varying the voltage on pin 5 also varies the duty cycle which can be detected with a simple RC filter.
Offline Lance
« Reply #37 on: April 04, 2011, 02:43:06 am »
I found this slightly amusing:
One person: I want to know what brand solder flux that guy is using and how much he's inhaling.
Another person: Holy jeez, I know! He is rather obnoxious.
#include "main.h"
#include <pic.h>
Offline ziq8tsi
« Reply #38 on: April 04, 2011, 04:35:49 am »
I do not detect any extra wires going to the breadboard, but I notice that Dave is working on top of a thin mat.  So I am going to suggest a loop antenna underneath transmitting the 55.5Hz signal.  With the cap missing, the breadboard spring would need to pick up well enough to put a few tens of mV swing onto the control pin (which is connected to the 5k-5k divider internally).
Offline DrGeoff
    • AXT Systems
« Reply #39 on: April 04, 2011, 01:13:46 pm »
Dave must be reading too much of 'Harmonic 695'! Maybe time to get out our tin foil hats :)
Was it really supposed to do that?
Online EEVblog
« Reply #40 on: April 04, 2011, 02:06:19 pm »
I get comments like that all the time!
They wouldn't now what enthusiasm is if it bit them on the arse.
Dave.
Offline itstemo1
« Reply #41 on: April 04, 2011, 04:48:14 pm »
Can we get a Detail Sketch (all the values and where you took your measurement).
I am new to electronics and just got myself a oscilloscope and I can't get the same wave form as you did. Sorry n00by speaking.
Offline FreeThinker
« Reply #42 on: April 05, 2011, 02:13:30 am »
Very interesting 1/2 second or so at about 2:15 are those wires to the bottom of the bread board? aerial?
MOONDOG
Offline Lance
« Reply #43 on: April 05, 2011, 02:34:01 am »
Dave.
Ha! You said arse...
#include "main.h"
#include <pic.h>
Offline steaky1212
    • Steaky - Sleep is overrated
« Reply #44 on: April 05, 2011, 02:55:22 am »
haha, busted i think
Offline neoone
« Reply #45 on: April 05, 2011, 07:25:41 am »
You meant that ?
Offline FreeThinker
« Reply #46 on: April 05, 2011, 08:04:52 am »
Yep! Looks suspiciously like an aerial coil or a pair of wires to me, could be just a wire clipping but the breadboard seems to be stood on some sort of mat. Makes me suspect some sort of magnetic loop or rfid type of thing (running out of ideas so any straw looks good  ;D)
MOONDOG
Offline insurgent
« Reply #47 on: April 06, 2011, 02:38:51 pm »
Just listened to the latest AmpHour. Definitely sounds like you nailed it FreeThinker!
Good thing Dave doesn't work for the CIA/NSA/FBI.  ;D
Offline FreeThinker
« Reply #48 on: April 07, 2011, 06:36:27 am »
Yahhh! Do I get a prize? Lol. .......perhaps a Tshirt 'I Sussed Dave 04/2011' (With my luck it would be one of those bloody lcd's he's trying to shift) Looking forward to to the reveal to find out exactly how it was done ;D ;D ;D
MOONDOG
Offline Mr J
    • Facebook mjssvt
« Reply #49 on: April 08, 2011, 11:16:21 am »
Check out my video response www.n1ir.com . Breadboarded multiple times multiple chips and still could not get it to oscillate? Watch video 7 and see me build it up. Might be a ground loop or picking up the mains (50 hz) all I can think of?
 N1IR, Mr J.
