Author Topic: iTunes EEVblog broken?  (Read 7147 times)
Offline billclayTopic starter
« on: July 15, 2013, 09:16:46 pm »
No episodes after 491 are showing up on iTunes.  Is there a problem?
Offline jancumps
  • New Low
Re: iTunes EEVblog broken?
« Reply #1 on: July 15, 2013, 09:24:50 pm »
Offline tsa
« Reply #2 on: July 17, 2013, 06:55:12 am »
same here, it stopped after episode #491.
Offline EEVblog
« Reply #3 on: July 17, 2013, 06:57:57 am »
I changed the itunes feed as an experiment. Have changed it back, but it could take a few days to update.
Please be aware that my continued support of the podcast version of the blog is not guaranteed, I do not intend to keep it going indefinitely.
Offline kaz911
« Reply #4 on: July 17, 2013, 11:06:09 am »
I would not mind "lower" resolution podcast feeds via iTunes. That should save a bundle.
Offline jancumps
  • New Low
« Reply #5 on: July 18, 2013, 06:35:29 am »
The iTunes podcast is now working for me, on an iPad.
I'm not using it - I watch via youtube - just subscribed as a test.
It is up to date including 495.
Offline tsa
« Reply #6 on: July 22, 2013, 09:37:54 am »
The iTunes feed still does not work for me (Germany) :(. Even within the iTunes Store, the feed shows only up to episode #491, so to resubscribe is not a solution. Can anyone in Germany confirm that?
Thank you
Thomas
« Reply #7 on: July 24, 2013, 09:20:51 pm »
USA iTunes store still stuck at #491.  It is a very convenient way to watch it on a Mac, so hopefully you will keep it going.  Thanks!
Offline EEVblog
« Reply #8 on: July 24, 2013, 10:25:43 pm »
I have no idea why it's stuck, I have restored everything to normal  :-//
Offline tsa
« Reply #9 on: July 29, 2013, 03:16:02 pm »
Still no further episode than #491. Would you mind to recheck the settings? I'm also using a Mac, and frankly I wouldn't change the iTunes  feed. Thank you Dave for considering us.
Offline tsa
« Reply #10 on: July 31, 2013, 02:41:30 pm »
While the iTunes Store (iTS) still shows only up to #491, I was able to update a newly added podcast, following this procedure:
Open up iTunes, go to File -> Subscribe to Podcast, enter http://www.eevblog.com/feed/ in the URL textbox, click ok. This creates a new entry in the podcast list called "EEVblog - The Electronics Engineering Video" [ the old one had  "Podcast feed" added to the name.
So I have two Podcast feeds now, the old one up to episode #491 and the new one (#463 - #501).  :)
This new podcast feed gets updated, so this means the feed.rss file is correct. As I circumvent the iTunes server, the error must be within the iTS. It looks that it does not update the feed anymore, due to a blocking status on the iTS side. Maybe you could contact Apple iTunes support to look into it, otherwise the EEVBlog probably vanishes from the iTunes directory...
I also looked at your feed.rss, I couldn't find any issue other than it's not nicely formatted  :(.
Hope this helps a bit to everyone.
Thomas
« Last Edit: July 31, 2013, 03:25:15 pm by tsa »
Offline r
« Reply #11 on: August 06, 2013, 11:46:43 pm »
steel no luck in the uk stuck at 491 have resuribed steel no luck (sorry for bay speling)
i do apologies for my bad speling and grammar as it took 19 year to figerout that im dislexic
Offline EEVblog
« Reply #12 on: August 07, 2013, 12:18:08 am »
As far as I can see I'm doing everything right on my server side.  :-//
I have reactivated the new-feed URL tag and will leave it that way.
Offline r
« Reply #13 on: August 07, 2013, 09:34:50 pm »
IT BACK UP TO DATE   :) :) :) :) :) :) :) :) :) :) :) :)
Offline EEVblog
« Reply #14 on: August 07, 2013, 11:31:29 pm »
Magic!
Offline tsa
« Reply #15 on: August 08, 2013, 04:49:17 am »
Yeas, it's working again with the old feed in iTunes. I rechecked iTS, this is working as well.
So it seems that: <itunes:new-feed-url>http://www.eevblog.com/feed</itunes:new-feed-url> did fix the problem.
Thank you Dave!
Offline EEVblog
« Reply #16 on: August 08, 2013, 06:50:00 am »
its didn't fix it the last few times I tried it!
