hi all. my first post to this forum will be a photo of my implementation of the 'active load' using the op-amp and mosfet.
on mine, I used an old cpu heatsink/fan, drilled and tapped holes for the various hot devices and mounted everything there. a small pcb stands off and holds the op-amp and a small molex for power and voltage-control.
also on the heatsink is a thermistor that I plan to use to cpu-control the fan (not shown but there's a fan behind this heatsink).
thanks for the cool idea, dave! I enjoy viewing your videos, although you are causing me to buy more equipment ..
/bryan
