Author Topic: That Antenna  (Read 2463 times)
Offline German_EETopic starter
That Antenna
« on: July 26, 2015, 02:46:27 pm »
Sorry Dave but I don't do Twitter. The antenna you spotted is a ham radio antenna  and it probably operates on all bands from 10m to 40m. They have various names and the following links give you some idea of the possibilities:
http://www.dj0ip.de/wire-beams/wire-beam-types/
http://www.scribd.com/doc/19452380/VK2ABQ-Beam-20m-15m-10m
My guess is a VK2ABQ Antenna but I could be wrong.
« Last Edit: July 26, 2015, 02:49:19 pm by German_EE »
Warren Buffett
Offline Tothwolf
Re: That Antenna
« Reply #1 on: July 31, 2015, 02:57:57 pm »
https://twitter.com/eevblog/status/625190862754938880
https://twitter.com/eevblog/status/625195496236134400
My first thoughts were that might be a multi-band shortwave reception antenna. That antenna's elements look like they are complete loops compared to the VK2ABQ design which uses two insulators per wire loop to turn half of it into a reflector.
http://homepage.ntlworld.com/m1bhp2/vk2abq.html
After looking at other designs, even though I can't make out any insulators in the photos, I have to agree with some of the other responses that it looks more like a G3TXQ CobWeb or G3TPW CobWebb style antenna.
« Last Edit: July 31, 2015, 02:59:31 pm by Tothwolf »
