The place were i currently have work experiance will be chucking out a large number of pelteir units.
Anyone want to buy them? With 12v across them, they draw about 5A each (have not measured properly as i had fans attached at the time)
each unit comes with or without heatsinks, the prices will be:
£12 + £8 for a pelteir plate peice:
£28 + £8 for a unit excluding backing plate:
£30 + £8 for a whole unit:
Buy 5 of any item and get 1 free! (contact me for postage costs)
Postage is for UK, contact me for postage outside of UK
Most aluminium frames of the units have bent corners, this can be fixed rather easly however.
These heatsinks are high quality machined heatsinks with the fins pressed and glued in for better thermal dissapation then extruded versions.
These units were used for special temperature controlled and logged fridges being sold at around £4,500. Each unit cost them around £400 to make,.
the units are unused and almost all are undamaged (best ones go first as there are only around 5 damaged ones). The pelteir plates are quality made,
not cheap china ones like on ebay as these products were top-of line.
The unit is about 440mm long, the fan ports pictures are standard size fans like those found in computer PSUs.
Pictures:
All the parts in a whole unit:
Fins on a heatsink:
Partially dissassembled:
Closeup of peltair unit:
I have over 45 so buy up while they last!
I prefure bank trans because there are no fees involved, however i will accept 'gifts' though paypal, but i will charge 20% more due to risk & charges (had bad experance with paypal)
I Also accept postal order, cheque by mail, or cash on collection, other suggestions are welcome
