2.5pF loading I'd say. ~5x lower than a typical 10:1 probe. I normally use 100:1 for the voltage rating, but have needed it for the low loading sometimes as well.
One thing to watch is the compensation range - might be a bit low for use with some scope inputs (i.e. check before buying!).
