What is the normal application for these?
Self renewing (liquid Mercury) contact surfaces, giving:
- Zero contact bounce, fast edges
- Ability to switch down to zero voltage and zero current (the only contacts that can do this)
- Constant contact resistance throughout life
- If used within ratings they have an operating life in the Billions of operations range.
Liquid Mercury Contact surfaces, meaning:
- They need to be mounted vertically (all contacts close when inverted)
- Don't like violent shaking (as above)
- They freeze at -38'C
They still have a useful place in one-off test equipment if you can get them (RoHS). They're perfectly safe if you don't break them apart... Hermetic glass reed encapsulation, inside potting compound, inside a metal can.
P.S. I don't mind singing their praises here, I've got my own stock.
