We have several thousand A123 LiFePO4 Nano-Phosphate modules for sale. These were all used in a highly controlled, cooled environment (using forced chillers) for 2 years. Each module has been tested for capacity and internal resistance (see test data below).
Module SpecsA123 ANR26650M1A Modules
Configuration: 12S8P (96 cells)
Voltage (nominal): 39.6V
Capacity (when new): 18.4Ah, 729Wh
Capacity (guaranteed): Minimum 14.5Ah, 574Wh
Dimensions: 31.5" x 3" x 6.75"
Weight: 18.75lbs
Cell Specs2.3Ah, 3.3V each
Performance: 30C continuous discharge, 60C pulse
Recommended Charge: 3A to 3.6V CCCV, 45 min
Fast Charge: 10A to 3.6V CCCV, 15 min
Power: Over 3000W/kg and 5800W/L
Cell Datasheethttp://e-motion.lt/wp-content/uploads/2010/01/ANR26650M1A_Datasheet.pdfModule TraysAlso available are modules trays consisting of 6 modules (total of 576 cells).
These trays are in 3S2P configuration. Nominal voltage is 118.8V, for a total capacity (when new) of 4372Wh.
PricingModules: $150 shipped (minimum 12 units, equivalent to $1.56 per cell)
Module Trays: $1050 shipped (minimum 2 units)
Shipping: continental US only
NoteMany of these cells sold online are knock-offs. These are 100% genuine A123 modules.
Pictures
