Author Topic: FA: (Texas) SMT Production Line Auction + Test Gear + Parts  (Read 8388 times)
Online EEVblogTopic starter
« on: March 31, 2017, 02:45:50 am »
MT & PCB ASSEMBLY EQUIPMENT
DEK Horizon Auto Paste Dispenser, DEK MPM 3000 Automated Solder Paste Application, Universal Radial 5 Auto Insertion, Universal Model 6287 AXIAL Insertion Machine, (2) Fuji CP643E Chip Shooter, Fuji CP IV-2 High Speed Chip Placer, Fuji IP-II Dual Head Chip Placer, Fuji IP-III Dual Head Chip Placer, Radial Lead Sequence Inserter Model 6348A, Electrovert Automated PCB Wave Solder System, Sniper II SMD-7007-5001 Flo-Master, PVA 650 Conformal Coating System, Acculogic Sprint FLS4510 Flying Probe Tester, Electrovert OmniFlo7 Reflow Oven, Electrovert Bravo 8105 Reflow Oven, Selective Soldering RPS Automation Rhythm, Stoelting Aqueous CBW-218 Automated PCB Wash System, Kutrite MCS-135BC Measure Cut & Strip Large Wire Process Machine, Schleunginer CS-9100 Cut & Strip Machine, Artos-CS-600 Wire Cutter & Stripper, Sniper II SMT/BGA/Chip Scale Placement and Rework System, Conformal Coatings Operations w/ Spray Booth, Coil Winding Systems for Solenoids & Electromechanical Devices, Vulcanizing, Molding, and Potting Systems, Pressing Stations and Much More…
QC, TESTING & SUPPORT EQUIPMENT
VisionMaster 400 Automated Laser Solder Inspection System, HASS TC-9 Temperature Test Chamber, MIRTEC AOI Machine MV-3 Series, Teradyne Z1890 Circuit Tester, Teradyne Z1880 Circuit Tester, Nicolet NXR-1400i X-Ray System, Cable/Harness Testing System, Matheson Tri-Gas Environmental Testing Systems, Soldering Stations, Mantis Scopes, Oscilloscopes, Function Generators, Multimeters, Attenuators, Analyzers, Inspection Tables/Lights, Temperature Controllers, Power Supplies, Hand Tools Plus Much More…
MACHINE SHOP
Complete Machine Shop with Milling, Turning, & Grinding Capabilities includes Enco Manufacturing X6323 Vertical Mill, Equitop ESG-618M Conventional Surface Grinder, Alliant 1 1/2 TMV Vertical Mill, Shark Metal Mover 17 X 33 Lathe and Much More…
PLANT SUPPORT
Air Compressors, Vacuum Pumps, Forklifts, Manlifts, Pallet Jacks, Hand Trucks, Assembly Tables, Rolling Ladders, Shop Fans, Wire Utility Carts, Pallet Racking and Much More…
OFFICE FURNITURE & APPLIANCES
Executive Desks, Chairs, Conference Tables, Office Panel Systems, File Cabinets, Computers, Printers, Bizhub 601 Copier, Projectors, and Much More...
INVENTORY
$2.5MM Inventory of Electronic Components, Electromechanical Assembly Parts, Wire Harnesses and Much More…
http://soldtiger.com/cgi-bin/mndetails.cgi?tigergrp259
« Last Edit: March 31, 2017, 02:57:25 am by EEVblog »
Offline xrunner
  • hp>Agilent>Keysight>???
Re: FA: (Texas) SMT Production Line Auction
« Reply #1 on: March 31, 2017, 02:49:13 am »
Oh yea ...  :box:
Online Brumby
« Reply #2 on: March 31, 2017, 02:55:43 am »
Texas is a bit far for me to drive...    :(
« Reply #3 on: March 31, 2017, 02:58:27 am »
Oh yea ...  :box:
Worth turning up to if you can get there.
No online bidding that I can see, so odds of getting bargains should be good.
Online Brumby
« Reply #4 on: March 31, 2017, 03:19:49 am »
That's not what I get from this:
STEP 3 – BID
Enter a maximum of what you are willing to pay under “Your Maximum” - The system will start your bid at the lowest available increment and bid for you.
Then scroll to the bottom of the page, enter your Bid Number and Password and click ‘Submit Bids’
(PLEASE NOTE: You will be asked to confirm your bids)
Important Bidding Notes:
- Items will close at a rate of 2-4 items every minute (varies by auction).
- An item’s closing time will extend by 4 minutes when bidding occurs within the final 4 minutes of its scheduled closing.
- If you submit a bid prior to the auction you will be notified if you are out bid.
- You may enter multiple bids on a page before clicking ‘Submit Bids’; however, changing pages will clear your bids.
Offline bitseeker
Re: FA: (Texas) SMT Production Line Auction + Test Gear + Parts
« Reply #5 on: March 31, 2017, 04:35:25 am »
« Reply #6 on: March 31, 2017, 05:37:46 am »
STEP 3 – BID
Ah, yeah, bummer.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #7 on: March 31, 2017, 10:08:14 am »
Finally one that is close to home! :)
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #8 on: March 31, 2017, 02:28:33 pm »
STEP 3 – BID
Ah, yeah, bummer.
If you're local, probably still worth going to have a look in case there are un-lotted items or a good dumpster
Day Job: Mostly LEDs
Offline rsjsouza
  • Eternally curious
« Reply #9 on: March 31, 2017, 03:50:42 pm »
STEP 3 – BID
Ah, yeah, bummer.
It's on my scheduler already! I only wish I had the space, the time, the $$$ to bid on one of these large PnP machines and play with it.
Mike, I suspect you would have fun with something like this:
« Last Edit: March 31, 2017, 03:52:35 pm by rsjsouza »
« Reply #10 on: March 31, 2017, 07:03:11 pm »
That's an oven, not a P&P....
Offline rsjsouza
  • Eternally curious
« Reply #11 on: March 31, 2017, 08:25:48 pm »
I know... The two sentences were supposed to be unrelated. The small pitfalls of the written word... ;)
Offline jrc22ski
    • SoldTiger
« Reply #12 on: April 05, 2017, 12:50:31 pm »
All,
The catalog with images and descriptions is now up and available here:
http://soldtiger.com/cgi-bin/mnlist.cgi?tigergrp259/category/ALL
Details on inspection day (open to the public / 17-Apr ), bidding, removal,l days, etc. on the sale main page here:
Feel free to contact m with any comments or inquiries.
Thank you,
John Coelho
Senior Director
Tiger Group | Commercial & Industrial
60 State St., 11th Floor
Boston, MA 02109
P: (617) 523-5866 | C: (617) 797-0430 | F: (617) 523-3007
jcoelho@TigerGroup.com
Offline jrc22ski
    • SoldTiger
« Reply #13 on: April 08, 2017, 12:32:41 pm »
Just released and available for purchase at the Tiger C&I April 18, 2017 McDonald Technologies, Inc. ("MTI") Online Auction Sale Event:
$2MM Inventory of Electronic Components and Electromechanical Assembly Parts. McDonald Technologies was actively producing product for customers thru January 2017.
Components include Common Electronic Devices such as:
Antenna, Battery, Boot Adapter, Buffer, Capacitor, CMOS, Connector, Contact, Crystal, Filter, Flash, Grommet, Header, Heatsink, IC, Inductor, Label, LED, Micro Controller, Modem, MSOP, Oscillator, Plug, Power Supply, Processor, Proximity Sensor, Reed Switch, Resistor, Sensor, Socket, Speaker, Switch, Transformer, Transistor, XCVR, XTAL.
Inventory available includes brand names in the electronics industry such as:
3M, ABRACON, ALLTRAX, ALPHA, Amatom, American EAGLE WHEEL, AMP Tyco TE, Amphenol, Analog Devices, Aptina, ATMEL, AVX, Bestan, BIVAR, BRADY, BROADBAND, CENTRAL, CINCON, CITIZEN, COILCRAFT, CONNER, CORNEL, CRYSTAL Semi, CTS, Cypress Electronics, Dale, Dallas Semi, Deutsch, ECLIPTEK, EFI, ELPA LCD's, EXAR, FAIRCHILD, FCI, Freescale, GENNUM, GLENAIR, Golledge, GORE, HALO, HELLA, Hirose, Honeywell, INFINEON, InnoDisk, Insight, Integra, Johanson, KEMET, KINGBRIGHT, KINGSTON, KOA, Laird, L-COM, LEDEngin, LINEAR Technology, LINK-PP, LITTELFUSE, LITTLE/TECCOR, LOCTITE, LS Research, M/A-COM, MAGURA, MAXIM Integrated, MCMASTER Carr, MEDER, Microchip, MICRON, MILLER, MOLEX, Motorola, Multitech, MURATA, NATIONAL Semi, NIPPON, NOVACAP, NVIDIA, NXP, Ohmite, Omron, ON SEMI, OPTIMA, OSRAM, P/CD, PANASONIC, PANDUIT, PARKER, PGI, PHASELINK, PIONEER, PMI/ANALOG, POLYSI, PROJECTS, QUADRASTAT, Raychem, REALTEK, REELL, Renesas, RF Parts, SAMTEC, SANDISK, SAWNICS, SEI, Semtech, Signal Quest, SIGNALQUEST, SIKAFLEX, Siliconix, Silvertel, SMSC, SPANSION, SPRAGUE, SRC, SSAC, ST Micro, Steward, SUNTSU, Supermicro, SUPERTEX, SUSUMU, T&B, Taiyo, TAOGLAS, TDK, Technologic Systems, TELIT, Texas Instruments (TI), TOKYO, Torex, TRIDON, Tripp Lite, TRIQUINT, UNITRODE/TEXAS, VENKEL, VISHAY, VITRAMON, WURTH, ZARLINK, ZETEX.
Those familiar with McDonald Technologies will recognize these customer prefixes which includes fortune 500 companies.
ADT, ANT, ANX, ASI, AVX, AWT, BAE, BAS, BBN, BCD, BEI, BOW, CAV, DAN, DAT, DIG, DIT, DVR, DWT, EGL, EKA, ELV, GAN, GFI, GTX, HAL, HFC, I/O, IDS, ION, KAY, KNG, LEN, LER, LLL, LOK, LSS, MIC, MTG, NED, NEO, NHW, NOR, NTS, OCS, ONN, PAR, PAT, PSC, RED, RFM, RMI, RUG, SAI, SAX, SKY, TTM, TUR, VIC, VRN, WAL, XTR.
More details, descriptions and images to be posted here:
Details on inspection day (open to the public / 17-Apr ), bidding, removal,l days, etc. on the sale main page here next week:
Thank you,
John Coelho
Senior Director
Boston, MA 02109
« Last Edit: April 08, 2017, 09:13:59 pm by jrc22ski »
Offline jrc22ski
    • SoldTiger
« Reply #14 on: April 12, 2017, 10:29:31 am »
Bidding is now open for all lots *EXCEPT THE INVENTORY🍸* here:
Registered bidders will be able to bid until auction close on 18-Apr.
There is also an inspection, open to the public, on 17-Apr from 10am to 4pm, all CST.
** inventory lots will be posted by tomorrow **
Thank you for looking,
John Coelho
Senior Director
Boston, MA 02109
Offline jrc22ski
    • SoldTiger
« Reply #15 on: April 12, 2017, 04:43:11 pm »
We are nearing the completion of the MTI Inventory referenced below and plan to add additional Lots to the sale by tonight (EST).
For the purpose of providing quantities, type, manufacturer and other perspective, attached please find 2 files:
(1) Top Dollar Inventory by Manufacturer and,
(2) Total Value / Entire Inventory (this file is too large/email me if you would like me to send)
Thank you,
John Coelho
Senior Director
Boston, MA 02109
Thank you,
John Coelho
Senior Director
Boston, MA 02109
« Last Edit: April 12, 2017, 04:44:51 pm by jrc22ski »
Offline jrc22ski
    • SoldTiger
« Reply #16 on: April 17, 2017, 01:16:00 am »
Preview will be tomorrow, April 17, 2017, at the MTI facility in Carrollton, TX and the auction will close throughout the day on Tuesday, April 18, 2018.
The previously mentioned inventory has been broken up in 25 lots and they can viewed in the following sort:
http://soldtiger.com/cgi-bin/mnlist.cgi?tigergrp259/category/INVENTORY
Thank you,
John Coelho
Senior Director
Boston, MA 02109
Offline rsjsouza
  • Eternally curious
« Reply #17 on: April 19, 2017, 02:32:32 pm »
John, it was a great auction. At least for me the online system worked really flawlessly. Congrats.
Offline Asmyldof
  • Freelancer - Persnicketist - Do'er of stuff
    • Asmyldof's Home. It's old, not quite impressive, but it's there.
« Reply #18 on: April 19, 2017, 05:49:20 pm »
Can you imagine stealing a whole rack's contents at bargain cost....
Unfortunately my company bank is too uptight to be convinced of loaning me enough. Or I need more training in outlining the opportunities involved.
If it's a puzzle, I want to solve it.
If it's a problem, I need to solve it.
If it's an equation... mjeh, I've got Matlab
(not really though, Matlab annoys me).
Offline rsjsouza
  • Eternally curious
« Reply #19 on: April 19, 2017, 09:04:51 pm »
I saw shelf after shelf of parts reels and was very surprised to see some pretty advanced and expensive parts there (AM5728, AD5933, Micron DDR) but these went for >$1,000 dollars. Perhaps cheap considering the amount of parts, but expensive for a hobbyist or perhaps a small company.
It was interesting to see some parts bins with mixed SMD passives - impossible to sort. :)
At any rate, I got a few gizmos for my lab. Pretty cool!
Offline gnavigator1007
« Reply #20 on: April 19, 2017, 09:27:02 pm »
What toys did you get? I wanted to bid on this one, but my schedule would not have allowed me to travel for the pick up. Contemplated shipping, but costs would have been too high
« Reply #21 on: April 19, 2017, 11:01:38 pm »
The problem with large lots of parts like this is realising any value from them without spending a lot of time. Anything expensive is the sort of part that normal buyers of that part will only buy from normal channels.
It's also a lot of work sorting & cataloguing. You may get lucky & spot one particular nugget and bid solely on the basis of that, and anything else is a bonus.
You can probably shift a lot on ebay over time but it's a lot of work - been there - done that!
Many years ago I bought a van full (big van, very full) of components at a tender sale of a bankrupt assembly house. A handful of items I'd previously spotted covered what I paid. Took a year or so part-time to clear most of it out on ebay, and I have a lifetime supply of a few bits like pin headers left.
It was initially a lot of fun going through boxes not knowing what I'd find, but got to be a pain after a while.
Offline rsjsouza
  • Eternally curious
« Reply #22 on: April 20, 2017, 01:08:16 am »
I got two bench DMMs on the cheap with valid cal and a few things and bobs.
Certainly. The distributors also guarantee origin and any defects - something that is harder to do for the higher priced items such as the ones I mentioned.
Also, one thing is have a couple dozen parts, other is have reels or a palette of 13,600 LiIon batteries (one of the items) - pretty hard to move, unless the planets align and you get an eager buyer.
For the larger items such as the oven above or the many PnPs, lead formers, chambers of all sorts, stencil printers, dozens of expensive stencils, it was an interesting (and sad) sight.
Offline Asmyldof
« Reply #23 on: April 26, 2017, 10:23:23 am »
Oh, you don't want to see the stock of reels and fully traced parts I already have.
A whole shelve of those reels would not get back on the market. Maybe half or such, but most would end up in my engineering stock for my Freelance Design service and Test Lab.
But the location and (to me) non-transparency of this event prevented me from considering the bid.
Offline USMC_Spike
« Reply #24 on: April 28, 2017, 12:35:14 am »
So anyone get anything from this event?
Did it work?
Cheers,
USMC_Spike
