Hi Chris,
I have always liked the look of the TG130. Very neat.
BUT.... for me, the Lepton 2 core resolution of 80 x 60 is too low for most jobs I use a TIC for. For this reason I have not bought one. If it contained a Lepton3, I would buy it.
The TG130 has temperature measurement but is really an enhanced FLIR version of the pretty poor FLUKE VT02 and VT04 visual thermometers.
If you read the specs and accept that it is the simplest of designs with virtually no menu options, then it may be a good buy.
For me, personally, I have recently been buying far more capable thermal cameras for £100 to £250. While I can obtain such, I have no need of the TG130 except as a curio. I have little room for marginal performance cameras.
If you want a simple 'point and measure' non contact thermometer that provides a more visual context, and far better measurement spot size, it is fine. For any form of more advanced work, I think you will grow out of it quickly. Remember, 80 x 60 pixels covering the provided 55 x 43 degrees field of view is not much detail. An FOV of 20 or even 12 degrees would have been better, but they are using a standard Lepton2 lens.
Best Wishes
Fraser
