they are now calling 'sensors' scopes?
this looks like a great sensor pod, a data collector and super duper a/d converter
I would think yes!
Compared to an USB oscilloscope (except for the really expensive Pico scope 6000 series), this one has the high sampling rate and the bandwidth of a 'real' scope, and an embedded controller so that it doesn't need the PC to run and will show a waveform with just the monitor attached. Granted, you need something to send commands to it so you may argue that it's a handicap rather than a something good. Also the advantage of having all waveform math, serial decoding and mask testing done by the Megazoom III ASIC is maybe offset by it being cumbersome to set up.
It features a lot of connectivity (USB, LAN, GPIB), the 16-ch MSO, external trigger in/out and 10MHz reference in/out. I would be willing to say that this is something a USB scope could easily do too but they generally don't. Also this one supports tons of nice Keysight probes with the AutoProbe interface.
It has the high resolution mode if you have spare sample rate. It also does equivalent time sampling up to 400 GSa/s if you turn off real time sampling by the way!
So I would not call this a sensor pod or data collector (digitizer), since it really is lacking the bit depth, memory and above all the fast data link compared to dedicated PXI solutions.
As Daniel and others noted this is a full blown 6000-series scope without the display and the user interface knocked off. I would agree that's a disadvantage for a professional using it for R&D on his desk but for a clever electronics person might overcome that by creating a small PCB with rotary encoders, buttons and an MCU that sends a mix of SCPI and VNC commands to control it.
This way it fills very little bench space (mount it under the shelf on your desk like a kitchen radio) and I at least have several monitors around my lab and they all have dual-input capability.
By the way, fire sale, now for 2300EUR incl. (EU) DHL shipping
