Neat board. Seems to have generated a good bit of interest.
How is the regulator mounted to the PCB? Is that a rivet? If so, it'd be nice to be able to more easily replace the regulator in case of an "input accident".
Aesthetically, and perhaps even practically, it'd be beneficial to have pin 13's LED further from the connector like you did with the RX/TX ones. That way, its placement looks similar, the pin label can go back in line with its neighbors, and you can see the LED better from that side of the board. Not a big deal, but a nice tweak.
For the photos, consider using a clean background (e.g., simple sheet of white or gray paper would suffice).
