Author Topic: SOLD: eBay [EU] Fluke 1912a 520Mhz Frequency Counter/Timer Calibrated 1p  (Read 1060 times)
Offline picitupTopic starter
Hi All
Up for sale on eBay is the above timer/counter in good working order.  The basic specs are:
    Channel A - 5Hz to 125mHz
    Channel B - 50MHz to 520MHz
    7 Digit LED display
    External 10MHz clock input at rear (see pic). This works perfectly with the BG7TBL 10Mhz gpsdo without amplification or buffering.
    Easy calibration by variable capacitor at rear
The eBay listing is here: http://www.ebay.co.uk/itm/263593027114 and it will be live at 20:00 GMT.
The user and calibration guide can be seen here:
http://bama.edebris.com/download/fluke/1912a/Fluke%201912A.pdf
Thanks for reading.....
Steve
« Last Edit: April 16, 2018, 07:11:42 am by picitup »
If you know what you're doing, then you're not learning anything.
Re: FS eBay [EU] Fluke 1912a 520Mhz Frequency Counter/Timer Calibrated 1p
« Reply #1 on: April 14, 2018, 06:10:45 am »
This goes at 20:07 GMT tonight.
Get it while it's hot!  :D
Cheers
Steve
