Author Topic: FS: New Various HP Avago 7 Segment displays, LEDS, Hobbyist components  (Read 3598 times)
Offline moff13Topic starter
  • Country: pt
I have a warehouse full of stuff I need to shift. So please consider me for Caps, resistors, (Radial, SMD) supplies/regulators, Dc / Dc converters, obsolete chips, Ics, FPGAs, Flash, Early Ram. Whatever your requirement Ill endeavor to sort you out. Everything must GO
Obsolete chip Examples: P80C31BH CHMOS 8-bit Microcontroller £2.99 delivered
                                        ISD1020AP Single-Chip Voice Record Playback Device £3.99 delivered
                                        TIl311 DIS1417 Hexadecimal Display with logic £2.25 Delivered
Large discounts for larger quantities
Mike EBAY Shop4ics
Part number    Description
Digital Displays
HTIl311A  Red Hexadecimal 6.86mm (0.27in)
HTIL311C Red Hexadecimal 6.86mm (0.27in)
HDSP-C2A1   AlGaAs Red 2.3” Single Digit PCB Based LED Display  (Common Anode, Right Hand Decimal)
HDSP-C2E1   Red 2.3” Single Digit PCB Based LED Display  (Common Anode, Right Hand Decimal)
HDSP-N103   AlGaAs Red 20 mm Low Current Seven Segment Displays  Common Cathode Right Hand Decimal
HDSP-7801   "Green 7.6 mm(0.3 inch) Micro Bright Seven Segment Displays viewing distances up to 3 meters (10 feet)
Avago HDSP-7801 Green 7.6 mm(0.3"") Micro Bright Seven Segment "
SA10-21SRWA   "Kingbright Super Bright Red 25.4mm (1.0 INCH) SINGLE DIGIT NUMERIC "
HDSP-3601   Green 7.6 mm (0.3 inch) Seven Segment Displays
HLMP-2885   LED Bar Graph Array, Green, 2.2 V, 20 mA, 8, 100 mcd, 8.89mm x 19.05mm
HDSP-523E   14.2 mm (0.56 inch) General Purpose Two Digit Seven Segment Displays
HDSP-5507   HER display ± 1 overflow device feature a right hand decimal point
HLMP-2550    Light Bar Green LED Display, 50 mcd
HDSP-C1Y3   Yellow 1.0” (25mm) Single Digit PCB Based LED Display
HDSP-5553   7-Segment CC Red LED Display, 1480 ?cd RH DP 14.22mm
HDSP-B03E   18:88 and 88:88 0.56" Four Digit GaP HER Seven Segment Display
HDSP-C3G3   Green 0.36” (9.1mm) Single Digit PCB Based LED Display
E30561 Toyo 3 Digit 7 segment Display
VFD20.0814FA Vacuum Fluorescent Display 8 Characters-7x5 Dots
Through hole Leds
l-59egw-ca   Kingbright  T-1 3/4 (5mm) BI-COLOR INDICATOR LAMP
HLMP-C223   T-1¾ (5mm) Super Ultra-Bright Red LED Lamps
HLMP-3316   T-13/4 (5 mm) High Intensity nondiffused LED Lamps narrow beam RED
HLMP-3650   5mm Standard LEDs - Through Hole Yellow Diffused 585nm 1.2mcd
HLMP-C423   AVAGO TECHNOLOGIES  T-1¾ (5mm) HLMP-C423  LED, 5MM, ORANGE
Surface mount
SML-210Ytt86    SML-21 Series Yellow LED, 6.3 mcd, 2-pin 0805 SMD Package
SML-511DWT86   SML-51 Series Orange LED, 40 mcd, 2-pin 0603 SMD Package
SML-512DWT86   SML-51 Series Orange LED, 100 mcd, 2-pin 0603 SMD Package
ASMT-JW32-NVVJ1   High Brightness LED, JADE Series, Cool White, 5700 K, 105 lm, 350 mA, 700 mA
HSMG-A100-k42J2   PLCC-2, Surface Mount LED Indicator Green
ASMT-JW11-NTV01   1W Mini High Power LED Cool White 90LM
Detectors
Tsop2136ya1   Vishay IR reciever Photo Modules for PCM Remote Control Systems
PIR LHi 958 LHI958 Pyroelectric Infrared Detectors dual element TO-5 954
  • Country: pt
Re: FS: New Various HP Avago 7 Segment displays, LEDS, Hobbyist components
« Reply #1 on: October 28, 2015, 09:19:32 am »
Still available
Offline neslekkim
  • Country: no
« Reply #2 on: October 28, 2015, 04:15:17 pm »
you don't have pictures of any of them?, I find myself googling one and one, and get tired ;)
Offline crispy_tofu
« Reply #3 on: October 29, 2015, 03:05:52 am »
+1  :-+
Say, would you have any quality 16V 22uF caps available? Planning to recap a meter.  ;)
  • Country: pt
« Reply #4 on: October 29, 2015, 06:27:47 pm »
+1  :-+
Sorry Mate I had a good look and I have 220u and 2200u but no 22 in 16V. Thanks for asking
