Nope still lemons. Has had new EGR valve, timing chain, front arms, shocks, window motor, brake cylinder, heating resistor, headlamp, clutch. The ECU and ignition system went pop during warranty as well. Last week the full beam headlights stopped working reliably due to a switch problem on the stalk.
Was mostly reliable until the day the warranty was up. It was on a flatbed the day after. Its only 5 years old and has done 42k miles.
To be honest bar the ECU, EGR and clutch, Ive done the repairs myself with a pirated service manual and some tools from machine mart so that's been OK. The Fiat dealer service is awful you see; took 11 days for them to work out how to replace the timing chain.
This is the same line of vehicles if that is any reference:
