ah, those looks nice, not bad priced either if one get them used.
Yes, you can get them used at good prices with a little patience. It's worth it for the quality. They're both linear power supplies and the lower-power E3630A is fanless, too.
Do you know if the input voltage on these are adjustable?, can't find any in norway, but lots of them on ebay, but I guess they have fixed input voltage?
I believe the 3630 is fixed input voltage. So, you have to get it with the proper rating. The 3631 has multiple taps on the primary. You select the voltage on the main PCB and change the fuse to fit the current rating for the selected voltage.
Buy the looks of it, it looks like E3630A and E3631A are totally different series also?, does not look alike at all? similarly with price?
Yes, they have different output limits, displays, cooling, etc. I included them as a couple of examples of good-quality triple-channel supplies with bi-polar output at a reasonable price on the used market. They also have good resale value if you decide to upgrade to something else later.
However, these aren't the only such supplies available, just something for you to get familiar with this type and know what to search for.
