Author Topic: Needed HP3457a front panel fuse assembly  (Read 1079 times)
Offline USMC_SpikeTopic starter
« on: November 20, 2017, 05:08:51 am »
Hi all,
At first I thought I only needed the front panel cap.
Now I realized I need the whole front panel fuse assembly,
front and back with wire that connects to the board.
This is for the HP3457a, I don't know if there are
other instruments with the same config, I assume so.
I couldn't find the part number from the manual either.
Thanks,
Cheers,
USMC_Spike
Offline rigrunner
Re: Needed HP3457a front panel fuse assembly
« Reply #1 on: November 20, 2017, 04:37:49 pm »
Just had a look in the SM for the 3457a and i think 2110-0565 is the part number for the fuse holder cap.
Internet of Things: A solution desperately trying to find its problem
The following users thanked this post: Mr. Scram
« Reply #2 on: November 22, 2017, 06:47:32 am »
@ rig runner,
Do you see something that says fuse holder internal?
or the like?  I need that part also.
Cheers,
USMC_Spike
Offline rigrunner
« Reply #3 on: November 22, 2017, 02:55:21 pm »
As far as i can determine FX101 and FX801 fuse holder/cap is part # 2110-0565 and the main body of FX101 and FX801 is part # 2110-0642
The front fuse holder on my unit is soldered to the A2 board and doesn't have a wire connected to it.
