Author Topic: Recommended Li-Ion/Li-Polymer Battery Supplier or Online Marketplace?  (Read 5816 times)
Offline MixedSignalSystemsTopic starter
    • Mixed Signal Systems
Hi guys,
Does anybody have a Li-Ion/Li-Po battery suppliers that they'd be happy to recommend? Alternatively, is there one of the many online battery specific online marketplaces that is worth spending some time on?
I'm looking to source a Li-Ion or Li-Polymer battery pack for a commercial project that I'm currently working on for a client.
The product is a portable device with a Bluetooth interface. I'd like a 3.7V Li-Ion or Li-Polymer battery pack with a minimum capacity of between 150 and 200 mAh.
There are plenty suppliers on sites such as EBay and Alibaba advertising seemingly appropriate battery packs. Sparkfun, Adafruit, etc. also sell appropriate battery packs in single unit quantities.
Most of the companies on Ebay, Alibaba, etc. are Chinese based and are unknown to me. In many cases, the documentation is also somewhat questionable and I'm struggling to pick a manufacturer that I have reasonable confidence in.
Also, the usual electronic distributors (Digikey, etc.) don't seem to stock many Li-Ion/Li-Po battery packs at all. I'm curious to know why. Shipping restrictions? Margin?
Many thanks,
Kieran
Offline notsob
Re: Recommended Li-Ion/Li-Polymer Battery Supplier or Online Marketplace?
« Reply #1 on: October 17, 2014, 07:21:34 am »
Have you looked at what's available for the hobby aircraft/helicopter market - try hobbyking
Offline Neilm
« Reply #2 on: October 17, 2014, 05:18:23 pm »
For a commercial product there are a load of restrictions on shipping - for instance I believe you have to ensure the product can't turn on during transit. That is why if you buy camera the battery is separate in the box, if you by a tablet it is held securely with a cutout to protect the power on off button. I believe if you ship more than a certain amount of batteries it has to be shipped as hazardous cargo.
What ever pack you use must pass the UN transport standard and any restrictions that are required by what ever standard your particular product has to meet.
I would suggest trying to find a battery that was reasonably easily available rather than going to get one built as you would have to pay for  the qualification and that isn't cheap. (for instance, one test requires 3 weeks to complete)
The only time I have had to source Li-Ion batteries were for a custom pack in a product I helped design a few years ago. I used a company called PBML based in Somerset to design, build and qualify them.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline TunerSandwich
  • I kiss on the first date
« Reply #3 on: October 20, 2014, 06:23:52 am »
Go to an OEM/ODM....you DO NOT want to get stuck with "counterfeit" Li cells.  Demand a point of origin paper-trail.
In Soviet Russia, scope probes YOU.....
Offline Neilm
« Reply #4 on: October 20, 2014, 09:07:05 pm »
Many of the OEM suppliers will not supply to the end user if the cell has to be assembled into a pack. They will only supply to registered pack manufacturers.
Offline Spikee
« Reply #5 on: October 20, 2014, 09:13:34 pm »
panasonic right ? :P
Freelance electronics design service, Small batch assembly, Firmware / WEB / APP development. In Shenzhen China
Offline Neilm
« Reply #6 on: October 21, 2014, 06:12:41 pm »
Sanyo, before panasonic bought them
Offline ManCave
« Reply #7 on: October 21, 2014, 09:37:44 pm »
Hi Kieran,
As suggested by notsob, have a look in model aeroplane stores. I had a requirement for a 160mA lipo cell before and have done my research and ended up talking to and ordering samples directly from Fullriver from China. They gave me quite a good service and the quality of the cells was pretty good. They are a quality supplier, I think their cells were used in the Pebble watch (if I'm not mistaken).
You will have to decide whether you want to buy the cells with integrated protection circuitry or whether you will design the protection into your own design. Don't forget that li-pos can be very dangerous if misused. Overcharging or high temperature can easily trigger an exothermic reaction which leads to really fast decomposition generating potentially (extremely) high temperatures.
On the other hand, over discharging (even few 100mV) will drastically reduce the life of the cell!
Good luck with you project!
Filip
Offline sca
« Reply #8 on: October 21, 2014, 10:20:48 pm »
I've had good service from Creasefield for a product in the last couple of years.
sca
« Reply #9 on: October 24, 2014, 01:04:46 pm »
That's not necessarily true for OEM.  Also that is why I suggested ODM if an OE won't take the job.  Many short run and one off pack assemblers out there, that will guarantee OE and prove it with paper....
Also 3.7 V is not a "pack", unless we are talking parallel config....but that seems unlikely with a 150-200 maH rating
« Last Edit: October 24, 2014, 01:07:39 pm by TunerSandwich »
« Reply #10 on: December 15, 2014, 11:50:21 pm »
Thanks for all the suggestions and input. I've been looking at the hobby sites for RC planes, etc. and couldn't quite find what I was looking for.
Recently, somebody suggested that PowerStream might be a good place to look for LiPo batteries for my application:
http://www.powerstream.com
Indeed it was. I found a range of appropriate batteries on their site.
It might be a useful site for other people looking for batteries for low-power portable applications.
Hope this helps.
Offline marshallh
    • retroactive
« Reply #11 on: December 16, 2014, 05:44:53 pm »
Batteryspace.com
I've bougt many plain cells from them
Verilog tips
BGA soldering intro
Offline uoficowboy
« Reply #12 on: December 19, 2014, 01:36:25 am »
Hi Kieran,
Filip
I've worked a good deal with Fullriver and was really happy with them. I've put their cells into multiple products that were entering mass production. No issues whatsoever. I've also visited their factory - their pouch factory is in an old schoolhouse - something like 7 stories tall. Not the highest tech facility, but definitely good enough.
Almost any American company you work with is just going to be acting as a middle man in terms of getting your cells made. That means more mouths to feed and higher cost to you.
