Author Topic: FS: new Fluke OC4USB and IR189USB replacement cable  (Read 3744 times)
Offline testpointTopic starter
  • Country: cn
« on: May 12, 2017, 04:42:23 am »
the price in Ebay is special for Fluke fans.
http://www.ebay.com/itm/Fluke-OC4USB-replacement-for-Fluke-scopemeter-97-99-105-123-124-192-196-199-etc-/182599416120
http://www.ebay.com/itm/Fluke-IR189USB-replacement-for-multimeter-87IV-89IV-187-189-189II-287-289-/182616112259
please be aware OC4USB and IR189USB using different style interface, can not exchange it though they using same circuit, and please be aware the earlier PCB (Rev I) used PL2303 chip, that will affect the transferring speed and stability, now all changed to FTDI FT232 (Rev II PCB).
« Last Edit: June 21, 2017, 12:37:12 am by testpoint »
  • Country: cn
Re: sell new Fluke OC4USB and IR189USB replacement
« Reply #1 on: June 03, 2017, 02:15:57 pm »
OC4USB cable, link to:
the cable is made for Fluke fans, also can use for Rohde & Schwarz FSH-3, FSH-6, FSH-18 spectrum analyzer for data collecting, you will Never meet such low price since I just got from the factory directly, and no more margin for sell. I only made 100 pcs for the cable using high quality material. I am also an electronic fan at least 30 years. the internal PCB as attached.
  • Country: cn
« Reply #2 on: June 21, 2017, 12:26:21 am »
drop the price to factory price, this is the only chance to get the such price cable in the world.
  • Country: cn
Re: FS: new Fluke OC4USB and IR189USB replacement cable
« Reply #3 on: July 17, 2017, 08:34:45 am »
now only remain OC4USB replacement, check the ebay link, 39 USD only:
http://www.ebay.com/itm/182599416120
  • Country: cn
« Reply #4 on: October 16, 2017, 02:23:48 pm »
  • Country: cn
« Reply #5 on: September 01, 2018, 02:04:14 am »
it is easy to open it, less than 10 second, no need any tool, I uploaded a video for that, if you found the cable loose etc, you can do the adjustment:
https://mega.nz/#!TX5VBJyK!WvF0R3pJUbx3k-Vtp2exVZBFEjE_jF_HPtMISqBcdeo
Offline Pattymorr
« Reply #6 on: August 23, 2019, 03:48:51 pm »
Please let me know if this http://omapalvelin.homedns.org/fluke/ is the base for your OC4USB.  I am looking some info for the  FSH3 interface.
Offline testpoint1
« Reply #7 on: August 24, 2019, 01:01:33 am »
FSH3/6/18 is same.
Offline Pattymorr
« Reply #8 on: August 28, 2019, 06:47:34 am »
Thanks for answer.
Found a little differences with the 189, seems like FSH series is more like the Fluke 287/289. I posted my solution here : https://www.eevblog.com/forum/testgear/enabling-options-for-rs-test-equipment/msg2616180/#msg2616180
Patty
Offline testpoint1
« Reply #9 on: August 29, 2019, 05:07:59 am »
Thanks for answer.
Patty
OC4USB is for fluke scope meter and FSH3/6/18. not for fluke 187, 287
