Problem is not the machine but the machine control system and the spare parts.
This thing is from 1996 so probably a MSDOS/Windows NT 3.5/4.0 OS on it, some essential (exotic) PC cards for controlling it or if you are lucky just the parallel port.
Keeping the PC alone alive and operating is a challenge. If something breaks on the machine where can you still get spare parts etc. etc.
I think it is easier to get parts for a 1950's american car than for a machine like this
By the time stuff like this hits the lowest end of the market, people aren't looking to be running it in the sort of all day every day maximum speed cycles it was designed for, so if you get something that was working when taken out of service (as opposed to taken out due to a failure) , chances are it will have enough life left in it to still be useable.
I'm sure there are some machines that have some terminal failure modes due to unobtanium critical parts, but remember that machines like this were made in small volumes, so will use standard parts where possible. there certainly won't be any custom chips in there!
Keeping an old PC alive isn't really a huge issue- as long as you have something with ISA cards, chances are you can run whatever vintage of OS is needed. Stuff like custom IO cards are a bit of a risk but electronics in general is reliable and often repairable .
Probably the biggest danger is getting something with no software, or missing calibration data. Even then it could be a decent platform for a DIY project, and will still have the hardest thing to DIY - feeders.
Obviously there is some gambling involved, but if you don't want to gamble, go out and pay $25K++ for a new low-end or refurbed mid-range machine. Nothing comes for free!
Before I got mine, I emailed all the UK used equipment dealers I could find asking what they had in the way of "project" machines under £10K, i.e. stuff that needed time rather than money spent on them. If I'd had the space I could have picked from at least half a dozen.
A major problem still is that all these old machines pre-date the web, so there is very little info out there, and companies that still support them are very unwilling to share info. The guy I got mine from was very pissed off about the forum I set up.
