Author Topic: WBT: JBC T245 Stand  (Read 2385 times)
Offline YsjoelfirTopic starter
WBT: JBC T245 Stand
« on: November 04, 2017, 10:52:07 am »
Hi everyone,
I'm looking for a T245 Stand that gives the possibility to use the power down features.
Can be totaly dirty and even somehow damaged, at least as long it stays in one piece.
Needs to get somehow to germany.
Thanks in advice!
Greetings, Kai \ Ysjoelfir
Offline on4top
Re: WBT: JBC T245 Stand
« Reply #1 on: November 08, 2017, 02:30:40 am »
also looking for such original stand ...but new way to expensive ..
meanwhile i'm using an old weller with a wire connected :-)
works perfect :p
« Reply #2 on: November 08, 2017, 07:56:23 am »
I have the exact same stand here. Might give it a try :P
The following users thanked this post: jeffaroo, on4top
Offline on4top
« Reply #3 on: November 08, 2017, 03:27:40 pm »
yep you really should .
found the pinouts here on the forum to make cable .. since my iron doesn't connect direcly to the station ( other connector )
Offline jeffaroo
« Reply #4 on: November 08, 2017, 08:06:25 pm »
For my DIY JBC I modified a Hakko stand to take the hand piece.
« Reply #5 on: November 08, 2017, 08:12:28 pm »
Java-Chai-Cafe-Foam? Sounds interesting. I like Coffee-Foam. And your Idea. What did you do to make the iron hold in there? I see some kind of metal ring?
Offline nanofrog
« Reply #6 on: November 08, 2017, 09:17:50 pm »
Hi everyone,
Thanks in advice!
Found a used one here in the US and the seller will even ship to Germany (here). Shipping and handling is insane however ($184.52  |O), but perhaps contacting the seller could fix this.  :-//
works perfect :p
Nice solution.  :-+
Offline jc101
« Reply #7 on: November 09, 2017, 07:14:03 pm »
I have a whole JBC CD-2BC soldering station shortly surplus to requirements, that does technically also contain a T245 stand if you really stuck - it will probably end up on here in the not too distant future.
Offline ilqpli
  • Country: hk
« Reply #8 on: October 16, 2018, 05:08:23 am »
