Hello members
Recently, my nilsen56 digital multimeter has been dying over the past two weeks or so. As my dad is a electrician, over ten years ago, he bought a multimeter from our neighbour. Our neighbour sells test gear and multimeters. Eventually my dad bought a new multimeter so i ended up with it. Im having trouble with the volts and amps range, and the capacitance range is completely dead (diplay shows nothing at all, not even zeros). Earlier i was mesuring the voltage on some capacitors. The multi meter read '0.1v'. When it should have read 10vor 100v.
Its unlikely that i will get a new multimeter, and i will get some other second hand meter, but i would like your help on buying a decent multimeter. It must be rated for atleast 400v ac and dc. Also it requires a amp, mA , and uA ranges, diode/continuity, and ohms. Backlight would be nice too.
Tell me what you think i should get. Preferably under 300 dollars
Thanks for all replies
