Author Topic: WTB: HP 5083-9039 CRT for HP 140S display section  (Read 1788 times)
Offline UglySteveTopic starter
« on: April 16, 2017, 10:49:29 pm »
I'm looking for a CRT for my Hewlett Packard 140S display section, part number 5083-9039.
Thank you,
Steve
Offline woodchips
Re: WTB: HP 5083-9039 CRT for HP 140S display section
« Reply #1 on: April 17, 2017, 04:56:32 pm »
A 140S isn't in the few HP catalogues I have, what does it look like? Round? Rectangular? Display grid pitch? Side pins? EHT voltage?
These older CRTs are easily swapped between equipment and manufactures, the only real problem is will it fit.
« Reply #2 on: April 17, 2017, 10:11:08 pm »
Woodchips,
It's a 5 inch round CRT with side pins. I believe the high voltages are -2350, and +5000V, like the 140T. I don't have the manual for the 140s.  I'm measuring -2180 and 4610 v.  What is display grid pitch?
Thanks,
Steve
Offline woodchips
« Reply #3 on: April 18, 2017, 05:37:38 pm »
Sure I have one from a 140. Whether it is worth sending is, of course, another question altogether.
The graticle is divided into squares, they can be 0.9cm, 1cm or 1.2cm most commonly, but I would assume the round CRT doesn't have an internal graticle anyway?
Look for a CRT from a 545 or similar scope, probaby fit. A rectangular CRT from the newer scopes should fit, need some metalwork though.
« Reply #4 on: April 18, 2017, 10:13:32 pm »
Woodchips,
Are you selling the CRT from a 140? Does it work? What is the part number? Do you have a picture. My 140S is a spectrum analyzer.
It may be worth shipping to the USA if it is a close enough fit.
Thanks,
Steve
« Reply #5 on: April 19, 2017, 06:48:56 pm »
I found a crt for a 140A I will try to buy, and make work.
Steve
« Reply #6 on: April 19, 2017, 09:22:30 pm »
I have a HP 5083-0652, from a 140A,  crt on the way. It seems to be the oscilloscope version of the spectrum analyzer crt I need.
If someone has a 5083-9039 crt for sale, I would still like to know.
Thanks,
Steve
« Reply #7 on: April 24, 2017, 06:34:24 pm »
Installed my new CRT. Works great. It's an oscilloscope tube, so the grid is different and the phosphor is faster, but it works.
Steve
