I'm needing to see if anyone here has an extra probe for the Boontoon 92E.
Is what I need to find.
Then, if anyone knows of a kit, or similar for the unit.
I would need the 50ohm, 75 ohm adapter presumably
to the two pin screw in connector of the Boontoon.
The Boonton part numbers are:
952001 R.F. Probe with low-noise cable and connector.
952001 50 Ohm BNC Adapter.
952004 Probe Tip (removable), with grounding-clip lead.
Thanks,
Spike
