Author Topic: WTB/LFS Older transistors (2SC1583 & 2SC91)  (Read 1724 times)
Offline aabbccTopic starter
« on: February 20, 2018, 12:26:32 pm »
I'm looking for the following:
  • 2SC1583 F (Preferbly suffix F but G works as well)
  • 2SC2291
Willing to buy anything from 1x to 100x
Got a bunch from various sources (ebay, utsource, various chinese sellers) but almost all I got were fakes  :scared:
« Last Edit: August 31, 2018, 12:22:16 am by aabbcc »
Online wraper
  • Country: lv
Re: WTB/LFS Older transistors (2SB, 2SC, 2SC)
« Reply #1 on: February 20, 2018, 12:43:45 pm »
    • 2x 2SB647 C (Must be suffix C and not AC)
    • 2x 2SD667 C (Must be suffix C and not AC)
    [/list]
    Strange requirement considered they are identical except AC has slightly higher Collector to emitter voltage. Most likely they were made with exactly the same process and then binned, where AC is higher grade.
    « Reply #2 on: March 22, 2018, 01:37:37 pm »
      [/list]
      Yea, I tried with the AC version and they did not work in the circuit I was intending on using them in.
      So I'm still looking :)
      Online wraper
      • Country: lv
      « Reply #3 on: March 22, 2018, 01:39:12 pm »
      Then the issue is with circuit, not transistors. If you think that transistors are so precise devices that C and AC would makes so much difference that circuit won't function, you're clueless. There likely is more deviation in parameters within C suffix than their average value differences between C and AC.
      « Last Edit: March 22, 2018, 02:18:11 pm by wraper »
      « Reply #4 on: August 31, 2018, 12:23:20 am »
      That might be the case that the issue is with the circuit, I don't really care tbh since its going in to an exact replica of an 80s synth :)
      Also, BUMP, only looking for 2sc2291 and 2sc1583!
      Online wraper
      • Country: lv
      « Reply #5 on: August 31, 2018, 07:49:52 am »
      Will you also use exactly the same part numbers for resistors and capacitors so it becomes exact replica?
