I forgot to say it has a 2 unit rack with the PSU......so i asked 50 euro more or less....
It is open to do the pictures you see in the post
Just to know what i would sell here
Is a 48V 6A linear PSU with no regulations,no voltage and current,nothing, but it's been all restored and all the components tested (the old big capacitors are been replaced with two new units for example).
The PSU is putted in a 3 unit rack case (a standard case, so 3 units corresponding to 13,5 cm x 49,0 cm) and a new black faceplate, it could be used for a beautiful linear PSU project (it's a good USA build PSU and not chinese......)......as i said in the first post each unit is in perfect working order because are been used till the last year for a professional audio stuff that now is been sold but without PSU.
One is been exchanged with an AC variac so only one left.
