You'll probably get better results if you look for 12 volt power supply, the term inverter generally applies going from DC to AC, whereas you're looking for the other way around
Meanwell is a pretty decent brand.
Since you're running a motor load I'd probably look for a 15 amp power supply or thereabouts.
motors take a lot more current to start and a smaller power supply might shut down.
Sent from my Fi Moto x4 using Tapatalk
