You know, it is one of those things: "I cannot see it and I dont understand it, so it must be dangerous."
What makes you think that those 180
scientists and and doctors do not understand the subject? Also this is subject only accessible to those who
want to understand it because tech and biology are not taught together in meaningful manner.
Now for more science based approach there are tons of research around incl relatively non-biased from former CCCP (little to no commercial factor).
Well I would have just pulled the power for that bugger.
Anyway I have heard that some one has found cameras in the rentals.
Of course I pulled the power
It was most ironic that I do not watch/own TV but there was one in the cabin and on this same evening there was short clip on TV about local RF research and general principles of being cautious consumer.
BTW electrical part of biology is actually very interesting. Ultrasound for example. There is lots of localized charged stuff in cells. Medical ultrasound is in HF range. Is there any consideration given to fact that charged stuff being physically moved around also generates microscopic/local RF hotsports in HF range? Cannot be detected from outside therefore does not exist...
Only semi-related mention was some CCCP research when they investigated very small cell groups electrical signaling patterns before/after ultrasound exposure and discovered that pattern changed to "attack/emergency mode".
