If you recently bought a cheap 3-prong power cord, or an appliance of questionable quality that included such a cable, you may want to check that it is wired properly. The right pin (with plug facing away) should be connected to the female pin labeled L (for live).
Not just recently. Back in the middle of 2013 I bought a cheap power cord off ebay so I could have a spare to use with something. I ended up using it a couple times and thats it.(it wasnt connected for long either time)(I wasnt working at the time, couldnt spend tons of money)
The cord says rated for 10A 250V, this is definitly wrong. The cord is thinner compared with a 10A 125V rated cord that I use for my computer. When I got the cord, I realized it was thinner but figured I didnt really care because I was going to be using it under an amp.
As it turns out, the polarity is also reversed in this one. Upon measuring it(just a few minutes ago), it also has the increased resistance of something like 1.1?.(I did take into account my test leads) Also, upon double checking my measurements, the thing was so shoddy that one of the female terminals broke. Glad I didnt use this much.
Guess I should buy a real one now.
So, recently? Not so much, there must be at least 1000s of these cord floating around out there now in the US. And they have been out there for a couple years at least. So, I would avoid buying any cords from china/ebay unless you are certain they are made properly.
