Unfortunately for what I wanted I didn't get much choice. There are a few laptops out there boasting DDR for memory with a HD screen
Yes, very few. Merely all of them.
Are there even any HD screen laptops with only DDR RAM? I thought the switch to DDR2 had already been completed when HD screen came on the market.
Oh, probably. But I was thinking of DDR as a general technology, not the first gen specifically..
I think he meant DDR4, actually, in which case.. he got lied to, because his laptop uses DDR3.
I think the name has been used over and over again by HP, I also found nothing specific when looking my model up. SANDRA reports:
SiSoftware Sandra
Computer
Manufacturer : HP
Model : HP 250 G5 Notebook PC
Family : 103C_5336AN G=N L=SMB B=HP S=250
Version : Type1ProductConfigId
Serial Number : CND63*****
SKU Number : X0N34EA#ABU
Chassis
Manufacturer : HP
Type : Notebook
Can be locked : No
Version : Chassis Version
Power Cord(s) : 1
Serial Number : Chassis Se***********
Asset Tag : Chassis Asset Tag
Boot-up State : Safe
Power State : Safe
Thermal State : Safe
Security State : External Interface Locked-out
Mainboard
Manufacturer : HP
Multi-Processor (MP) Support : No
Model : 81EB
Type : Mainboard
Version : 61.30
Serial Number : PFXPQI2*******
Asset Tag : Type2 - Board Asset Tag
Location in Chassis : Type2 - Board Chassis Location
Mainboard Properties
Removable : No
Replaceable : Yes
Hot Swap : No
On-board Devices
IGD : Video Adapter (Disabled)
Hanksville Gbe Lan Connection : Ethernet Adapter (Enabled)
Other : Other (Enabled)
3165NGWG : Other (Enabled)
Chipset
Model : HP Core (Skylake-U) ULV Host Bridge/DRAM Registers
OEM Device Name : Intel Core (Skylake-U) ULV Host Bridge/DRAM Registers
Revision : A9
Bus : Intel CSI (Quick Path)
Front Side Bus Speed : 100MHz
Width : 20-bit / 20-bit
HTT - Hyper-Threading Technology : Yes
Maximum Bus Bandwidth : 400MB/s
Maximum Power : 3.400W
Features
VT-d - Virtualisation Technology : Yes
Chipset 1 Hub Interface
Type : DMI (Direct Media Interface)
Version : 1.00
Multiplier : 0x
Logical/Chipset Memory Banks
Bank 0 : 8GB SO-DIMM DDR4 15-15-15-36 4-51-17-9 3T
Bank 2 : 8GB SO-DIMM DDR4 15-15-15-36 4-51-17-9 3T
Shared Memory : 770MB
Maximum Memory : 32GB
Supported Memory Types : DDR3 SO-DIMM DDR4
Channels : 2
Width : 128-bit
Memory Bus Speed : 2x 1GHz (2.13GHz)
Multiplier : 32/3x
Integrated in Processor : Yes
Maximum Memory Bus Bandwidth : 33.34GB/s
Memory Module
Manufacturer : Samsung
Model : M471A1G43DB0-CPB
Serial Number : 9812****
Type : 8GB SO-DIMM DDR4
Technology : 8x(4096Mx8)
Speed : PC4-17100SO DDR4-2132
Standard Timings : 15-15-15-36 4-51-16-5
Interface : 1.00
Memory DC Line : 1.200V
Temperature Sensor(s) : No
Timing @ 1164MHz : 16-16-16-38 4-54-17-6
Timing @ 1091MHz : 15-15-15-36 4-51-16-5
Timing @ 1018MHz : 14-14-14-34 4-48-15-5
Timing @ 945MHz : 13-13-13-31 3-44-14-5
Timing @ 873MHz : 12-12-12-29 3-41-13-4
Timing @ 800MHz : 11-11-11-26 3-37-12-4
Timing @ 727MHz : 10-10-10-24 3-34-11-4
Memory Module
Serial Number : 980F****
Interface : 1.00
Sensor
Model : Hewlett-Packard PABAS0241231 BAT
Mainboard Specific Support : No
Sensor
Model : Intel Core CPU [P1, C2, T7]
Version : 78.03
CPU Temperature : 39.00°C
Voltage Sensor(s)
CPU DC Line : 0.897V
Battery DC Line : 17.028V
Capacity Sensor(s)
UPS/Battery Capacity : 40.61Wh
System Bus(es) on Hub 1
Version : 2.30
System Bus 0 : PCI
System Bus 1 : PCIe 3.00 x1 2.5Gbps
System Bus 2 : PCIe 3.00 x1 2.5Gbps
LPC Hub Controller 1
Model : HP Sunrise Point-LP LPC Controller
OEM Device Name : Intel Sunrise Point-LP LPC Controller
Revision : C2
ACPI Power Management : No
Advanced TCO Mode Support : No
RNG - Random Number Generator : No
Disk Controller
Model : HP Sunrise Point-LP SATA Controller [AHCI mode]
OEM Device Name : Intel Sunrise Point-LP SATA Controller [AHCI mode]
Interface : SATA
Revision : C2
Specification : 1.10
Maximum SATA Mode : G3 / SATA600
Channels : 2
In Use Channels : 2, 100%
Port : G3 / SATA600
Port : G1 / SATA150
Disk Controller
Model : HP Sunrise Point-LP PMC
OEM Device Name : Intel Sunrise Point-LP PMC
Revision : C2
Audio Device
Model : HP Sunrise Point-LP HD Audio
OEM Device Name : Intel Sunrise Point-LP HD Audio
Revision : C2
Type : HD (High-Definition) Audio
Version : 1.00
No. In / Out / Bi-Directional Streams : 7 / 9 / 0
No. Serial Data Streams : 1
Audio Codec
Model : Realtek Semi 0282
Revision : A4
Version : 1.00
Audio Channels : 6
USB Controller 1
Model : HP Sunrise Point-LP USB 3.0 xHCI Controller
OEM Device Name : Intel Sunrise Point-LP USB 3.0 xHCI Controller
Revision : C2
Version : 3.00
Specification : 1.00
Interface : XHCI
Channels : 18
Companion Controllers : 64
Supported Speed(s) : Full (12Mbps) High (480Mbps) Super (4.8Gbps)
Legacy Emulation Enabled : No
SMBus/i2c Controller 1
Model : Intel ICH SMBus
Version : 2.01
Specification : 2.00
Advanced TCO Mode Support : Yes, Disabled
Slave Device Enabled : Yes
PEC Support : Yes
Speed : 100kHz
Expansion Slot(s)
J6C1 (1h) : PCIe x1 PME Hot-Plug Used
J6D2 (2h) : PCIe x1 PME Hot-Plug Available
J7C1 (3h) : PCIe x1 PME Hot-Plug Available
J7D1 (4h) : PCIe x1 PME Hot-Plug Available
J8C1 (5h) : PCIe x4 PME Hot-Plug Available
Port Connector(s)
J1A1 - Keyboard : Keyboard / PS/2
J1A1 - Mouse : Mouse / PS/2
J2A1 - TV OUT : Video / Mini-DIN
J2A2 - CRT : Video / DB-15 pin female
J2A2 - COM 1 : Serial Port 16550A / DB-9 pin male
J3A1 - USB : USB / USB
J5A1 - USB : USB / USB
J5A2 - USB : USB / USB
J5A1 - Network : Network / RJ-45
J9G2 - OnBoard Floppy Type : Floppy Disk
J7J1 - OnBoard Primary IDE : ATA
J30 - Microphone In : Audio / Mini-jack
J30 - Line In : Audio / Mini-jack
J30 - Speaker Out : Audio / Mini-jack
Ctrl0Port0 - Primary HDD Bay* : SATA
Ctrl0Port1 - Secondary HDD Bay* : SATA
Performance Enhancing Tips
Warning 2542 : Memory bus speed exceeds Chipset rated speed. Reduce FSB/memory multiplier.
Warning 2513 : TPM not detected. Some security features are unavailable.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
