Its true that for every type of application, there is specialized thermal probes.
And according to that rule, the basic K type probe that come with the DMM, or you additionally get,
it serves basic measurements that high accuracy and fast temperature changes its not important.
The topic was looking fishy from the start, because the expectations was not logical if we think that some one expects the ultimate accuracy by a 10$ probe.
Lets hope that Agilent will offer to me the true professional K type probe for review.
It retails about 180$ , and yes this one it supposed to be accurate all the way for a Year time.
The low cost basic probe it supposed to be used for heatsink temperature measurements,
somewhere between 30 to 80C .
No one cares if the heatsink would be hot as 51 or 53C, and there is no critical difference to that,
and so the low cost K type probes are good enough about this task.
And now I will offer one practically valuable tip.
And this called as K type probe matching.
You need to have a minimum set of three identical K-Probes,
You test all three , and by this comparison, you accept as best the one who gives the middle reading.
And you mark the difference with a permanent marker on the other probes like ( example at 20C) +1 ( 21) and - 0.5 ( 19.5).
And now you can use any of the three, and you known what to expect from its one.
