So, 3D printers, good for Lego heads and chocolate roses...
Imagine you've got a hammer and like bashing in nails, then someone shows you a screwdriver... what use could that possibly be? The tip is too small to hit anything and the handle gets damanged by screwheads if you try that end.
It's surprising what you can find to make with some tool once you have the tool, but before you acquire it you can't see why you'd want one. Two of my projects this week:
1. Curtain rail stop. Missus complains about the stop missing so the curtains run right off the end of the rail (as they do). No problem: take the remaining one and knock up an exact copy within an hour.
2. Missus (again! I should start charging) wants a custom thread winder thingy for attaching to her spinning wheel. Taking a bit of thought, this, but without the printer it wouldn't even occur to her that it could be done, never mind me actually do it.
When I'm bored I download another cable clip design off thingiverse and tidy up some cables. Every time someone brings their PC or laptop for me to fix up I return 'em with all the cables nearly stowed, so this adds background value to other things I do.
A 3D printer is not a panacea for everything, but it does offer possibilities you wouldn't dream of otherwise.
