Author Topic: All Purpose non-Conductive Adhesive?  (Read 5042 times)
Offline PhysicsDude55Topic starter
« on: October 14, 2018, 05:59:32 pm »
I'm looking for some all-purpose non-conductive adhesive to use for my electronics projects.  Preferably the same cloudy schmoo (some call it hot snot?) that's smeared over loose componenets in manufactured electronics.  I tried doing some searches, and couldn't find much.   Tried searching the usual places I buy electronic components from, but all I can really find is thermal paste and thermal conductive epoxy.
I don't need it to be thermally conductive.  I just want to squirt some goo on electrical components, connections, wires, etc. that's non-conductive and readily available/cheap.
I've tried hot glue with little luck.  Is normal silicone caulk any good for this purpose?
Offline CatalinaWOW
Re: All Purpose non-Conductive Adhesive?
« Reply #1 on: October 14, 2018, 06:09:55 pm »
A lot of what I find smeared over electronics is hot glue.  I have used it pretty successfully myself.  As with all adhesives surface type and surface preparation matters more than adhesive type.  Oily surfaces will stop most adhesives, including hot glue.  There are several varieties of hot glue, you might try experimenting with others.  Also, since hot glues flow into place fairly well but are viscous enough to hold their shape you can often achieve a mechanical bond even if adhesion is not successful.
RTVs also work pretty well, given adequate surface prep.  Here there is even more variety than in hot glue, and the ones that smell like acetic acid on curing are not recommended for electronics (though I have used them with some success.)
Offline Mr. Scram
  • Display aficionado
« Reply #2 on: October 14, 2018, 06:12:40 pm »
I think you're looking for Silastic and its non name brand brethren.
https://en.m.wikipedia.org/wiki/Silastic
Offline cowana
« Reply #3 on: October 14, 2018, 07:59:56 pm »
If going with RTV, make sure you get a type designed for use with electronics. The standard 'bathroom sealant' grade are made of acetic acid, and will cause long term corrosion if they get in contact with copper or component legs.
Offline rdl
« Reply #4 on: October 14, 2018, 10:01:58 pm »
I built a small power supply board many years ago. I used a board mounted transformer and to insulate the mains AC traces I covered them with a small rectangle of thin polystyrene plastic glued down with Loctite RTV silicone glue - the acetic acid smelling kind. I didn't actually use the board and tossed it in a drawer. About 4 or 5 years later, after hearing of the potential problems with that type of adhesive, I removed the plastic sheet and inspected the traces, but I didn't see any evidence of corrosion.
« Reply #5 on: October 15, 2018, 05:01:05 am »
Thanks for the replies.  I used hot glue in a project where I had wires soldered to very small traces on an existing PCB, and the wires kept popping off while I put everything back into the case.  After applying the hot glue, it very obviously was a decent conductor and wrecked havoc on my arduino inputs.
I ordered some "704 Adhesive Silicone Rubber" from china for cheap.  The electronics silicone adhesive I found from US suppliers or Amazon prime was like $7-10 per tube, this stuff is $2 per tube.  We'll see how it works out.
Offline tooki
« Reply #6 on: October 15, 2018, 01:44:01 pm »
No way hot melt glue is a good conductor. If it were, thousands of DIY projects and countless millions of commercial gadgets would be malfunctioning. Whatever happened with your Arduino project, it wasn't because of hot melt conductivity.
Offline wraper
  • Country: lv
« Reply #7 on: October 15, 2018, 02:00:24 pm »
In power electronics where such adhesives are used the most I barely ever seen a hot glue used. And the reason for that if pretty obvious. And many times I've seen hot melt, it already came off but I never seen this happen to silicone.
Offline Zero999
  • 0999
« Reply #8 on: October 15, 2018, 03:59:04 pm »
As mentioned above hot melt glue is a good insulator. In fact most adhesives are good electrical insulators, apart from the water based ones. The fault with your Arduino project was not caused by the glue.
There's a reason why electronics silicone adhesive is more expensive than the cheap stuff. It's because it doesn't emit acetic acid, vinegar, whilst curing, which can cause corrosion problems, especially in soldered connections. What's worse is the acid emitted can evaporate and condense on other parts, causing more corrosion.
Offline wraper
  • Country: lv
« Reply #9 on: October 15, 2018, 04:13:05 pm »
That's acetoxy type (vinegar smell). But you can also buy usual neutral cure RTV silicone (actually there are several types of those, like alkoxy) in hardware store as well. It's just there is no spec/guarantee about it's conductivity, dielectric constant, dielectric strength, dissipation factor.
« Last Edit: October 15, 2018, 04:16:18 pm by wraper »
Offline GeoffreyF
« Reply #10 on: October 15, 2018, 06:01:04 pm »
Why do you want to do this?  Manufactured products have different requirements than home brew ones.  Manufacturers may wish to stabilize the components for shipping. They may wish to prevent tampering for warranty reasons.   They may find it less costly to glue something down than to provide a mechanical fixation for it.  Of  course there are still reasons to use glue but less than a manufacturer has.
What you did not mention when you said "non conductive" is what the dielectric of the glue should be or whether it might prevent a part from dissipating heat properly.  Not thermally conductive is one thing - a "Blanket" is another.   In general, my thinking is that less is best.
If it's home brew you may not know when you might want to make a change - that's another difference with manufactured stuff.
US Amateur Extra W1GCF.
Offline thm_w
  • Non-expert
« Reply #11 on: October 15, 2018, 09:48:54 pm »
Yeah for DIY electronics get the Silicone type 2 from home depot/etc, price is the same from what I saw as the acetoxy cure (type 1). White or clear is available.
https://www.homedepot.com/p/GE-Silicone-2-2-8-oz-Clear-Window-and-Door-Caulk-GE500-3TG/100179996
https://images.homedepot-static.com/catalog/pdfImages/66/664fb1c9-6aed-43dc-88d7-3a10bff81124.pdf (no acetic acid)
