Author Topic: Audiophile Ethernet card! Finally!  (Read 15524 times)
Offline daqqTopic starter
  • Country: sk
    • My site
« on: July 21, 2017, 07:41:06 am »
Finally, I can listen to the Internets properly!
http://jplay.eu/ml_post_slider/jcat-net-card-femto/
Some highlights:
External PSU option
Even though there are ultra-low linear power supplies exclusively on the JCAT NET Card FEMTO, for best performance it is recommended to connect external linear 5V PSU (such as our 200W or 400W linear PSUs) as the source of power instead of using computer PSU.
Sure, why not?
• Industrial grade components with operating temperature range from -400 to +850
(gotta get me one of those -400 components!)
For customers who would like to purchase x2 NET Cards FEMTO (for Dual PC mode), the price is 800EUR (instead of 844EUR). Ask for the discount via email!
Awesome! Finally I can listen to the Internets in stereo for a discount!
The following users thanked this post: nugglix
  • Country: sk
    • My site
Re: Audiophile Ethernet card! Finally!
« Reply #1 on: July 21, 2017, 07:44:25 am »
Holy crap! The rest of the products are even more audiophilish!
http://jplay.eu/jcat/
 :wtf:
Offline NivagSwerdna
« Reply #2 on: July 21, 2017, 07:47:17 am »
Uses http://www.crystek.com/crystal/spec-sheets/clock/cchd-957.pdf
Crystek’s Model CCHD-957 HCMOS CLOCK oscillator family has been designed specifically for High Definition
Audio (HD Audio). It features a typical low close-in phase noise of -100 dBc/Hz @ 10 Hz offset, and a noise floor of
-169 dBc/Hz. With this extreme low phase noise performance, you will “Hear the Difference”.
[I may be offline for a while whilst I cryogenically freeze my ethernet cables]
Offline hans
« Reply #3 on: July 21, 2017, 08:17:52 am »
They probably lack the required documents and skills, but man these guys must be craving to build a x86 or ARM based computer with TCXO CPU clocks, linear CPU rail regulators and shielded memory bus interfaces.
And then amplify the price by preferably 50 times.
• Requirements for optional PSU: 5V/1.5A min
:-DD
Offline CJay
« Reply #4 on: July 21, 2017, 08:31:58 am »
Don't let them go below absolute zero or you'll mess up the tachyon ordering of the bits and end up listening to the music in the wrong order.
Online wraper
  • Country: lv
« Reply #5 on: July 21, 2017, 08:54:37 am »
 :wtf:
LOL
« Reply #6 on: July 21, 2017, 09:15:43 am »
Thnkas for the adcive. I will baer that in mnid
The following users thanked this post: CJay
Offline vealmike
« Reply #7 on: July 21, 2017, 10:07:51 am »
If this accidentally happens, compensate by cooling your ears to exactly the same temperature.
By removing thermal noise directly from your eardrums, this will of course deliver a listening experience that you'll be totally unable to fault - something true audiophiles strive for.
« Last Edit: July 21, 2017, 11:37:30 am by vealmike »
Offline CJay
« Reply #8 on: July 21, 2017, 10:38:21 am »
I have, more than once, put forward the theory that dipping entire audiophiles in liquid nitrogen overnight would silence the spurious background noise they generate.
The following users thanked this post: Zbig, Cyberdragon, IRFP460, Cubdriver
Offline RGB255_0_0
« Reply #9 on: July 21, 2017, 10:45:41 am »
You should also check out their forums. A wealth of information laughs to be had.
Your toaster just set fire to an African child over TCP.
Offline Ampera
    • Ampera's Forums
« Reply #10 on: July 21, 2017, 10:49:27 am »
Man, this would go great with my 1000$ HDMI lead so I can get the best video quality and audio quality.
I forget who I am sometimes, but then I remember that it's probably not worth remembering.
EEVBlog IRC Admin - Join us on irc.austnet.org #eevblog
Offline RGB255_0_0
« Reply #11 on: July 21, 2017, 10:51:26 am »
SATA, ethernet, and USB cables are only 349 euros each. Bargain compared to that $1000 HDMI cable that may not even be 2.0b compliant(?).
Offline CJay
« Reply #12 on: July 21, 2017, 10:54:42 am »
This is just going to run and run...
For extra laughs go and read the websites for the products mentioned in said forum.
There's what seems to be a bottomless pit of golden ears audiophile BS to mine
Offline madires
  • A qualified hobbyist ;)
« Reply #13 on: July 21, 2017, 11:32:11 am »
Oh my! Perhaps we should start knitting audiophile socks >:D
Offline orolo
« Reply #14 on: July 21, 2017, 11:33:29 am »
I see a business oportunity here! How about a well tempered 300 baud modem, synchronized with a cesium reference (you don't want your bits drifting) and a 100W class A audio output with silver heatsinks and galinstan liquid metal cooling with magnetic pumping? A discerning audiophile must hear each bit coming in.
Offline et328
« Reply #15 on: July 21, 2017, 11:57:03 am »
Ethernet allows almost endless extra audio tweak possibilities: dynamic vs. static IP, does 10.10.x.x sound better than 192.168.x.x, sound differences between router ports and what is the correct cable direction (twisted pair direction). And of course all the usual audio device tweaks also effect ethernet devices.  :o
Offline BrianHG
« Reply #16 on: July 21, 2017, 12:07:15 pm »
 :palm: Will this ever end?
I can understand in an analog amplifier maybe having a better more rugged power transformer and better DC power caps, but, in this digital BS, the only part that matters is the DAC and it's clock in the analog output device.  Anything else would be a failure in broadcasting the error free digital data from point A to point B.
Funny, when I use my WiFi, filled with local interference and lousy clocking and noise, the exact same bit-stream reaches my sound card's output whether it was in the originating computer with it's HD, on an Ethernet cable talking to the remote HD, or on the WiFi doing the same, over even over the 'internet' where who knows, every other device in the link throughout the world wide web is guaranteed to not have audiophile grade components.
« Last Edit: July 21, 2017, 12:15:46 pm by BrianHG »
Offline CJay
« Reply #17 on: July 21, 2017, 12:27:20 pm »
Same thing with power cables, the miles of cabling back to the powerstation seem to be conveniently ignored yet chucking a couple of metres of pure crystal aligned unobtanium BS fixes all that...
Offline madires
« Reply #18 on: July 21, 2017, 12:41:33 pm »
Yes, when there are no humans anymore ;)
Some people like to ignore the fact that data (including audio streams) is buffered if passing through networks.
« Last Edit: July 21, 2017, 01:43:25 pm by madires »
The following users thanked this post: BrianHG
Offline nali
« Reply #19 on: July 21, 2017, 01:11:58 pm »
Class A subnets will sound better of course!
Offline hans
« Reply #20 on: July 21, 2017, 01:56:39 pm »
Should hack the OS to use port 0 for audio streams, it has less digital noisy edges than say the very noise ports 21845 (5555h) or 43690 (AAAAh).  :popcorn:
Offline DG41WV
  • Country: lk
« Reply #21 on: July 21, 2017, 03:05:17 pm »
Better switches and network cards may benefit the performance of an AoIP  network but the stuff in that website on OPs post is bullshit.
https://www.telosalliance.com/Axia/What-Ethernet-Switches-has-Axia-Approved  <- link to some actual audio grade stuff
Offline CJay
« Reply #22 on: July 21, 2017, 03:33:15 pm »
Odd, they look very much like Cisco switches with a new front on them, I wonder what the etch on the boards says...
*edit* ha, they are Cisco. So, not audio grade, 'just' enterprise grade.
« Last Edit: July 21, 2017, 03:35:14 pm by CJay »
Offline Fsck
  • sleep deprived
« Reply #23 on: July 21, 2017, 03:49:39 pm »
Puny humans, how can you forget proper storage? Gotta store it on an audio grade SSD such as found in: https://www.audiodestination.co.uk/digital-64/digital-media/melco-audio-n1zs20-mk-ii-2-tb-audio-grade-ssd-high-resolution-music-server-and-usb-media-player-direct-cd-import  lest the electrons fall out of your music.
Why only a gigabit adapter though? They should've made a push for 100Gb. Gotta stream at maximum speeds so latency doesn't affect your music enjoyment.
"This is a one line proof...if we start sufficiently far to the left."
Offline RGB255_0_0
« Reply #24 on: July 21, 2017, 04:09:01 pm »
Gotta use that PCIe 3.0 for that 10b/8b encoding so no stray electrons.
