Maybe someone could tell me the technical reason why this happened.
It's worth keeping in mind that hard drive command sets include the ability to reflash the hard drive firmware. Which means there's potential for hostile code on the PC to deliberately brick hard drives, by reflashing the drive firmware with garbage. There are obvious scenarios in which this could happen (hackers, intelligence agencies, etc), but there are also non-obvious ones.
I have a story that may be relevant. Long ago I swore I'd never give MS another cent, for anything, under any circumstances. So I have an interest in unofficial versions of Windows. A few years ago I was setting up a system using an 'optimized and minimized' version of WinXP. The system HD was all FAT32 partitions. I'd spent about a month on and off getting the system customized and all utils I wanted installed. Never even a hint of any problems. I reached the point where I was happy with it, and so should make a duplicate system image. A suitable spare drive I had was NTFS. Before reformatting it I thought I'd check what was on it. Powered down the system, plugged in the NTFS as 2nd HD, powered up. Spent a brief moment looking at the contents, decided it held nothing important and formatting it would be OK. I wasn't logged in as Administrator, and the quickest way to switch was via a reboot. So shut down the system and powered up again. Btw, both drives were PATA, and on separate cables. I didn't touch anything during this sequence.
On this power up, the system wouldn't boot. 'Missing hard disk'.
On investigation, the system boot HD I was about to mirror, was now a non-HD. Bricked, not responding to the BIOS at all.
So, that drive just happened to become a brick, in the couple of minutes when this 'black' Windows install saw an NTFS drive for the first time ever, after being fine for a month of use, many power cycles, many reboots, both from power downs and ctl-alt-del restarts.
It's not an impossible coincidence, but it sure makes me suspicious.
If I was a paranoid person (and I am) I'd suspect there's code buried in Microsoft NTFS drivers that runs some kind of 'am I a legitimate Windows install?' check, and if not, causes as much pain as possible.
Now if I was writing a 'hidden last resort protection' code bomb like that (and I have in the past) I'd make it non-deterministic in operation, ie it wouldn't always act, and it wouldn't always do the same thing when it did act. Repeatability is a weakness and allows for easier recognition, identification and removal. Also, since I'm convinced Microsoft management are the worst imaginable kind of bastards, I don't think it's beyond the realm of possibility that such drive-bricking behavior might also happen at rare, random times, solely to create a background of such failures in which more targeted failures don't stand out so much. Which would put a couple of other such sudden total drive-failures I've had in a different light.
One of those projects I'll probably never get around to, is to set up that same scenario, but with target HD having the _write line to the HD firmware flash physically cut, and a logic analyzer looking at the PATA interface and that write line. Also using a system with a CPU emulator installed. It would be cool to catch it happening, and document exactly what code did the drive bricking. Imagine the class action lawsuit, if it turned out MS Windows actually was provably deliberately bricking drives now and then.
Edit to add:
PowerCartel, a blog, and forum, focusing on scavenging and reusing lithium ion rechargeable batteries.
http://powercartel.com/
http://discourse.powercartel.com/ <-- not working?
Thanks for the links! You should start a thread on this. 18650 batteries are great, and I'm already finding lots of surplus ones. Very interested in discussions of salvage/restoration & charge management techniques.
Pic below - the green ones are all good, as they were found (in DECT phone battery packs) while still charged, mostly brand new. The yellow ones are an interesting experiment-to-be, in that they are from a portable power tool pack and are COMPLETELY flat. 0.0V. But the first one I've tried charging is showing signs it might recover somewhat. Still to be seen how it goes with multiple 'resuscitation cycles'. I'm very curious about how badly these batteries are degraded by mistreatment.
