The nightmares of disk drive repairs....
I think the worst system I worked on was a NOVA (Data General). We are talking about a computer with all the lights and switches on the front. The hard disk had two platters. One was removable. I think these were 14". The heads have to be parked and they had a way to retract them is the power went out. The problem is they pulled them back so violently that it would knock the heads out of alignment.
The stupid plastic parts inside the MFM 20MB MiniScribe drives would outgas and make a film that would lock the drive heads to the platters. Saw after effects of people attempting to spin them... They used steppers, so no servo data on the media back then. I pulled a few of these apart and cleaned the heads and media with no clean room. Just gloves, non lint wipes and alcohol. Reformat the drive and done. My success rate was pretty good.
When I bought my first LeCroy scope for home, the 7200 with the VME bus, what drive was in it? The 20MB MiniScribe! They wrote the software to support only a couple of different drives. Of course the one with the unit was locked up. Not wanting to relive the 80s, I had a good working 20MB Seagate that I tried (these were bullet proof). No luck, the software would not allow it to work. Using a logic analyzer, sniffed the MFM bus between the two drives, then modified the Seagate to look like the MiniScribe. I still own this scope and it still has the Seagate drive inside and running.
The last one I managed to get the data off, person was working on a large project and had not backed up their data in a few weeks.
Drive dies of course. Started hearing some BS about a fridge.
I manage to get the drive, pull it apart (again no clean room or anything) and found the flex strip running to the heads had shorted internally (amplifiers were on this Kapton Polyimide something flex board) I pull out the flex and attempt to blow the short open with a power supply. This worked long enough for the PC to boot (Windows, so what, 10 minutes). Drive dies, recheck and the board is again shorted. So I soldered a couple of pins onto the flex board and hooked up an external supply to drive it.
Managed to recover the entire drive. I took a picture of it and it ended up getting photo shopped into a reminder poster about backing up your data.... True story.
